window won't go back up...??? - Mustang Evolution
Old 08-19-2012, 08:26 PM   #1
02 360R's Avatar
I let my window down and went for a ride. I made it back to the house & only the passenger side would go up. I swapped the switches still nothing. Fuses look good. I do not know what else to look for... maybe a motor? Please help!
02 360R is offline   Reply With Quote
Old 08-19-2012, 09:26 PM   #2
infamous281's Avatar
Re: window won't go back up...???
Happen to me and I went crazy and pryed the window with a flat head and it rolled up .____.
Old 08-19-2012, 11:21 PM   #3
Just hold the window button for it to go up and hit the door right in the middle. Right below the arm rest. Worked for me
bluegrassfever6 is offline   Reply With Quote
Old 08-19-2012, 11:37 PM   #4
Vegas97gt's Avatar
Region: Nevada
Does the motor still make noise? If it does it's the switch is bad. If the motor doesn't its the motor and you can test it by pulling your door panel unplug the motor hook the motor up to the battery And if it rolls up or down its good if not replace it
Vegas97gt is offline   Reply With Quote
Old 08-20-2012, 01:02 AM   #5
dray492's Avatar
I had the same problem, I actually bought my mustang with the window stuck down. Anyways the motor wasn't making any noise so I thought it was shot had a buddy who is an electrician try a bunch of stuff with no luck, his neighbor comes over because he is a mustang enthusiast and saw us working on it, he goes to unhook the motor so we can manually roll the window up and BAM it started working, somehow the gears locked up or something, but *** soon as he loosened the motor bolts it started working. So give that a try.
dray492 is offline   Reply With Quote
Old 08-20-2012, 03:27 AM   #6
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
Happened to me, hold the button for the direction you want it to go and close your door kinda hard and wa-la its goes up
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
Old 08-20-2012, 03:36 AM   #7
Stockish302's Avatar
Hit the door!!!!! Happend to my friend today just pound the door a bit till it goes back up.
BBK cai, 96 tbird maf housing, BBK 70mm TB, TFS intake manifold, BBK shortys, bassani off road X pipe, Flowmasters with turndowns
If any one is willing to donate parts to the Make Joe's Mustang Faster that Corvettes Foundation, donations will be gladly appreciated
Stockish302 is offline   Reply With Quote
Old 08-20-2012, 04:29 AM   #8
sean03gt's Avatar
I've had this problem constantly especially in the summer i think its caused by the window motor getting overheated if you put it in the shade and wait it usually works or take the door panel off and I've had too before undo the bolts that hold the window motor on and that seems to unjam it hope this helps
sean03gt is offline   Reply With Quote
Old 08-20-2012, 09:21 AM   #9
jdavis96gt's Avatar
Region: West Virgina
Sometimes I hold door open and try. That's how I do my passenger window everyday. Think its pretty common problem. I've taken apart and cleaned everything and nothing. I've heard hold down button and hit door too.
Old 08-20-2012, 11:26 AM   #10
02 360R's Avatar
Motor does not make a sound. I tried beating the door. Still nothing. I removed the switches and tried everything I can think of and NOTHING! I haven't tried the motor and a jumper wire to the battery though. I'll try it in a few.
Old 08-20-2012, 11:42 AM   #11
02PONY's Avatar
Take door panel off , push upwards on window switch and tap motor with a hammer at the same time your pushing button
02PONY is offline   Reply With Quote
Old 08-21-2012, 10:19 AM   #12
02 360R's Avatar
Woo hoo!!!! It's working! Removed the door panel and gave it a few bumps and magic happened! Thanks to everyone for your great advise! That window really had my spirits down.
Old 08-21-2012, 11:52 AM   #13
as said, slam/hit the door a couple times and try and repeat. The window motor is going bad~ they like to do that
Old 08-21-2012, 12:28 PM   #14
02 360R's Avatar
Do you recommend a new motor or one from the salvage yard? It is working like a champ now...
Old 08-21-2012, 08:24 PM   #15
02 360R's Avatar
Originally Posted by tonina911 View Post
Just hit it like i mention and it will last u for a while
Cool. Thanks!
07:39 AM
