08-19-2012, 10:10 PM
#1 | | Registered User
| Looking to upgrade 96 gt
I was wondering what the best way to make my 96 gt faster, on a budget so nothing to fancy. Car has minor mods already, pi intake manifold, electric fan, and wider back tires. Any ideas what I should start with??
08-19-2012, 10:12 PM
#2 | | Registered User
Longtube headers
08-19-2012, 10:13 PM
#3 | | Registered User
Gears are always a good bang for the buck.if you have the time and knowledge, I would suggest finishing off the PI swap
2000 GT-
Engine: K&N cold air intake, Bassani offroad x, Magnaflow catback, Bama 91 octane race tune, 3.55 gears dyno'd at 233whp 272wtq before exhaust
Suspension: IRS swap with stock cut 03 Cobra springs
Brakes: Front and rear brakes from an 03 Cobra with EBC Yellowstuff pads
08-19-2012, 10:18 PM
#4 | | Registered User
| Quote: |
Originally Posted by JDF Gears are always a good bang for the buck.if you have the time and knowledge, I would suggest finishing off the PI swap | Ok, I'm mechanically inclined but I would have to learn more about the pi swap to do it. Would it be better to buy new heads online or try to find some used ones from a 99-03 gt?
08-19-2012, 10:20 PM
#5 | | Registered User
| Quote: |
Originally Posted by Mitchel3408
Ok, I'm mechanically inclined but I would have to learn more about the pi swap to do it. Would it be better to buy new heads online or try to find some used ones from a 99-03 gt? | If you have the cash then I would upgrade to Trick Flow heads but for the money PI heads are a great swap for the NPI engines. I've seen PI heads on craigslist for as cheap as $400 for the pair.
2000 GT-
08-19-2012, 10:45 PM
#6 | | Registered User
| Quote: |
If you have the cash then I would upgrade to Trick Flow heads but for the money PI heads are a great swap for the NPI engines. I've seen PI heads on craigslist for as cheap as $400 for the pair. | What do I need to look for on the pi heads before you buy them to make sure there all good?
08-19-2012, 11:19 PM
#7 | | Registered User
| Quote: |
What do I need to look for on the pi heads before you buy them to make sure there all good? | I'm knot quite sure. I would look in the combustion chamber for nicks and scratches. But other than that I'm not sure what to recommend looking for.
2000 GT-
08-19-2012, 11:23 PM
#8 | | Registered User
| Quote: |
Originally Posted by Mitchel3408 I was wondering what the best way to make my 96 gt faster, on a budget so nothing to fancy. Car has minor mods already, pi intake manifold, electric fan, and wider back tires. Any ideas what I should start with?? |
PI heads are gnna be a waste of time
Just do Gears/Cams/Full Exhaust
08-19-2012, 11:34 PM
#9 | | Registered User
| Quote: |
Just do Gears/Cams/Full Exhaust | Why do you say that?
2000 GT-
08-19-2012, 11:38 PM
#10 | | Registered User
| Quote: |
Just do Gears/Cams/Full Exhaust | Why would they be a waste? Wouldn't I need to upgrade the air intake and full injectors to get power out of the cams? Or would the be fine with out it?
08-19-2012, 11:39 PM
#11 | | Registered User
| Quote: |
Why do you say that? | Heard of ppl making way.more power by just adding cams
And if your gnna do all that work might aswell get some high flowing badass heads in there.
08-19-2012, 11:43 PM
#12 | | Registered User
| Quote: |
And if your gnna do all that work might aswell get some high flowing badass heads in there. | Oh gotcha, what gears would you use after changing the cam?
08-19-2012, 11:44 PM
#13 | | Registered User
| Quote: |
And if your gnna do all that work might aswell get some high flowing badass heads in there. | Cams won't net you the same power that swapping the PI heads will, but swapping cams on he PI heads wouldn't be a bad idea while you're at it.
2000 GT-
08-19-2012, 11:45 PM
#14 | | Registered User
| Quote: |
Oh gotcha, what gears would you use after changing the cam? | 373 are perfect ---------- Post added at 12:45 AM ---------- Previous post was at 12:45 AM ---------- Quote: |
Cams won't net you the same power that swapping the PI heads will, but swapping cams on he PI heads wouldn't be a bad idea while you're at it. | Research it !
08-19-2012, 11:48 PM
#15 | | Registered User
| Quote: |
Cams won't net you the same power that swapping the PI heads will, but swapping cams on he PI heads wouldn't be a bad idea while you're at it. | Alright, how much horse power would the pi head gain me? 40ish?
08-19-2012, 11:56 PM
#16 | | Registered User
| Quote: |
Alright, how much horse power would the pi head gain me? 40ish? | Yeah. The full PI swap should put you at 270ish at the crank.
2000 GT-
08-19-2012, 11:59 PM
#17 | | Registered User
| Re: Looking to upgrade 96 gt
But if he's going to do cams why not go PI?
2004 Mustang Mach 1 - SY
Exhaust - Wanna be Flomasters...
JLT Ram Air Intake
SR Performance Short Throw Shifter
08-20-2012, 12:05 AM
#18 | | Registered User
| Quote: |
Yeah. The full PI swap should put you at 270ish at the crank. | Ight cool thanks man
08-20-2012, 12:16 AM
#19 | | Registered User
2000 GT-
08-20-2012, 12:26 AM
#20 | | Registered User
08-20-2012, 09:26 AM
#21 | | Registered User
Just look on cl and find some pi heads, get stage 2 cams and out in them and you'll notice a hell of a difference.
