odometer not working - Mustang Evolution
Old 03-13-2008, 05:38 PM   #1
hi everyone my 96 gt has 173083 miles on it. the other day the odometer and trip meter quit,the spedometer works fine.does anyone know what the problem is and how to fix it? thanks
98mustang2007 is offline   Reply With Quote
Old 03-18-2008, 09:54 AM   #2
1234's Avatar
Re: odometer not working
it sounds like a speed sensor i believe on that transmission there is a cble and a wire the cable it the speedo and the wire is the odometer
Old 03-18-2008, 12:50 PM   #3
the VSS sensor is what he is talking about above (at least on 99 ups its called that) on pre 99s there is a speedo gear. Check that sensor, if its bad... but when mine had issue the speedo didnt work either.
Old 03-18-2008, 02:11 PM   #4
Send a message via AIM to jwil86
i had this problem on my 96... the problem was the plastic gear in the instrument cluster broke. you can open yours up and see if thats the problem (takes like 10-15 minutes) if so you can get a replacement from Odometer Gears | 72 Croatan Road | Newport News, VA 23606 | 757.593.3478
96 v6 mustang: dual exhaust, 99 GT wheels
coming mods: 4.2 swap, cam, cold air intake, ported heads and lower intake
jwil86 is offline   Reply With Quote
Old 03-20-2008, 10:25 AM   #5
1234's Avatar
i put a t 45 in my 03 gt and the issue was my tach still worked but my speedo was off the gear on the vss was the wrong one. but there was an electrical plug and a cable plug in on it. the cable plug is for the speedo and the electric plug is for the tach and the odometer and trip meter. at least im pretty sure
odometer and Trip not working Tim Knox 1996-2004 Mustang GT 2 07-19-2008 12:12 AM
odometer 98mustang2007 Pre-2005 V6 Mustang 2 03-28-2008 04:14 PM
What to do when replacing Odometer? fast64 General Car Discussion 5 01-17-2008 08:52 AM
What does your Odometer read? DarkShadow General Car Discussion 54 06-18-2007 09:53 PM
Speedo works, Odometer does not.. floridamba Pre-2005 V6 Mustang 9 04-24-2007 03:02 AM
01:15 PM
