Building a 4.6 - Mustang Evolution
Old 08-21-2012, 06:12 AM   #1
Building a 4.6
How much top end work will be needed to add a 75mm throttle body + a bigger throttle body housing to a 4.6 to make it run right ? I bought the car this way , just trying to find out some info if I can .
scooter569 is offline   Reply With Quote
Old 08-21-2012, 06:30 AM   #2
tc x 4's Avatar
I don't think it'd be wise to build a motor around a tb. You need one that will work with your heads/ cams/ and intake. Talk to a reputable engine builder.
Old 08-21-2012, 06:32 AM   #3
02PONY's Avatar
I run 75mm tb and plenum mine runs great.
02PONY is offline   Reply With Quote
Old 08-21-2012, 06:38 AM   #4
Re: Building a 4.6
I bought the car with some work done . Just trying to find get a idea how much was done to it . The people I got the car from had no clue .
Old 08-21-2012, 07:52 PM   #5
32vNomad's Avatar
Re: Building a 4.6
Well really without any background you would be best to tear it down to be certain. I mean the best you can do is take the valve covers off and check if there are cams, but other than that your in the dark. A stock plenum won't benefit from a 75mm throttle body. There are many selections out there. What direction are you wanting to go?
32vNomad is offline   Reply With Quote
04:48 PM
