Rims again...I'm so lost. - Mustang Evolution
Old 08-21-2012, 11:01 AM   #1
Constantine's Avatar
Ok..at my job I get a discount on Falken...tires and rims. I don't know what rims to drop on my Mustang..well..I know the rims, just not the size and bolt pattern. etc..
RT-7M Wheel - Falken Wheels
I want those...But what sizes?
I know one thing...I want 18x9 up front and 18x10 in the back. I don't see that there...I just googled and it says my bolt pattern is "114.3"
Should I get them? Also...I don't understand this "offset" thing.
Sorry guys..I've been into engines since I was a pup, but never really bought brand new rims.
Constantine is offline   Reply With Quote
Old 08-21-2012, 11:16 AM   #2
Lorraine's driver
ab_mach1's Avatar
Checkout this Wheels and Tires sticky
Wheels and Tires FAQ
Instagram: @ab_mach1
Old 08-21-2012, 11:40 AM   #3
Re: Rims again...I'm so lost.
18x9 = 275/35/18 (you can run a 265 but a 275 adds a touch more lip protection)
18x10 run a 295/35/18 or a 305 wide tire
every tire maker varies in width, its no standard honestly but thats what I have and I like
Old 08-21-2012, 11:51 AM   #4
Lorraine's driver
ab_mach1's Avatar
Do 275's up front put too much stress on the front suspension?
Old 08-21-2012, 11:58 AM   #5
no, not that I know of> I have had them on my 97, 01, and 2003. They are factory on 03 cobras~ you may have a slight rub if you turn it at a full lock, the 03/04 cobras have a rack limiter to stop it from rubbing. Its not a big deal just FYI
Old 08-21-2012, 12:09 PM   #6
Venomouz831's Avatar
Hmm never thought of running a 275, I run 265 and 305, I heard a 275 will affect something performance wise but I forgot what.
)02 Gt, Founder of WE2G
Old 08-21-2012, 12:11 PM   #7
Lorraine's driver
ab_mach1's Avatar
Do the 305's stick out past the fender?
Old 08-21-2012, 12:34 PM   #8
No but you will rub if u are dropped
Old 08-21-2012, 12:35 PM   #9
Alright...That's strange.
Well...I don't have any luck finding the rims on my car right now, so I don't know what the biggest tire they'll fit it.
The on in my avatar picture. Those are my rims. What's the biggest sized tires those will take.
Right now it has 245/45 up front and 235/55 in the back -___-
What the biggest I can go on those wheels?
Old 08-21-2012, 12:56 PM   #10
Lorraine's driver
ab_mach1's Avatar
I think the Machs were 1/2" lower than stock GTs. I'll have to investigate. Prolly need new tires by February
Old 08-21-2012, 01:00 PM   #11
How wide of a rim do you have?
---------- Post added at 12:00 PM ---------- Previous post was at 12:00 PM ----------
Half and inch won't make you run if I go with a wide tire.
Old 08-21-2012, 01:15 PM   #12
Don't hate me...But I don't know
Any idea? They're the ones in the pic I have.
---------- Post added at 01:15 PM ---------- Previous post was at 01:06 PM ----------
OEM RIMS FACTORY WHEELS STOCK RIM CHROME REPLICA WHEEL USED RIMS Wheels OEM RIMS FACTORY WHEELS STOCK RIM CHROME REPLICA WHEEL USED RIMS Rims
Is it those?
Old 08-21-2012, 01:17 PM   #13
Lorraine's driver
ab_mach1's Avatar
Is it those?
Can't really tell from your avatar. Do you have a bigger pic?
Old 08-21-2012, 01:19 PM   #14
Is it those?
Yea I can't tell from the pic but if you have a 9 inch rim 275 is the widest you can go. 8 inch rim 255
Old 08-21-2012, 01:27 PM   #15
I'm trying to upload pics now..It's being a mission..lol we don't have "tapatalk" anymore?
I hope they're at least 9's
I don't think 275's all around will be too hot right? I mean...I want 275 up front and would like 285 in back...but should I settle for 275's all around?
Old 08-21-2012, 01:35 PM   #16
Old 08-21-2012, 01:52 PM   #17
I can't tell if they are 9 inch wide rims, you have to take off the rim and look in the inside. 275 all around is fine, if u want to go staggered then 275 in the back and 255 I'm the front is a good setup. But remember if you go staggered which means a wider tire in the rear you won't be able to rotate you're tires and be more cost towards u.
Old 08-21-2012, 02:03 PM   #18
Well then...that's a good way to look at it with being staggered. I'll leave them all @ 275's all around then. Good call brother. Thank you!
What's your setup?
I'm going to check under my car now. I may just order the tires today so they're here by Friday. If I can see the #'s. lol
Old 08-21-2012, 02:36 PM   #19
What's your setup?
You're welcome, it's more cash effective if you run the same size all around, but the staggered look is better for grip n looks better. I run 18x9 265 continentals and 18x10 305 hoosier drag radials.
Old 08-21-2012, 02:49 PM   #20
That looks badass...Love it.
I guess I'll just hit 275's
I'm on Eibach pro kit springs.
So what height should I do? 45's?
Old 08-21-2012, 02:54 PM   #21
Thnks. How much of a drop is tht? And what is you're current height on ure current tire n rim. And you're planning on using the same rims you have right? Also are ures 17 or 18's
Old 08-21-2012, 02:58 PM   #22
I think it's 1 & change. Pretty sure 1.5 rear and front.
I have 18's right now.
Old 08-21-2012, 03:01 PM   #23
Oh ok you should be fine running a 45 tire then. So you're goin to run 275-45-18 right. I would rather opt for a 40 but it's the same. The 45 will fill the gap better anyways
Old 08-21-2012, 03:04 PM   #24
I was thinking about going 40 too...but the gap thing. Hit the nail on the head then. lol Thanks brother! I'll order the tires Monday. Too late now.
Awesome! Still wanna make 100% anyways that they're 18x9's
Appreciate it greatly man.
Old 08-21-2012, 03:06 PM   #25
No problem man were all here to help! Yea make sure first!
Old 08-21-2012, 04:33 PM   #26
Lorraine's driver
ab_mach1's Avatar
You got a drop too, don't ya?
Old 08-21-2012, 05:12 PM   #27
RUNNWLD's Avatar
Region: Utah
On my stock 17x8 rims bullits I fit a 275 on mine for the back and a 245 up front
RUNNWLD is offline   Reply With Quote
Old 08-21-2012, 05:55 PM   #28
Yes I do
11:22 PM
