Isos with h&r springs - Mustang Evolution
Old 08-22-2012, 10:05 AM   #1
RUNNWLD's Avatar
Region: Utah
Am thinking of not using isos on the front and 1 in the rear? If I do this is there a difference in what one I take off in the back? If anyone has some pics of there setup with lowered stands and will say what the setups I would gladly appreciate it!!
RUNNWLD is offline   Reply With Quote
Old 08-22-2012, 10:53 AM   #2
infamous281's Avatar
No Iso is No Problem ..
Lower it more too
Old 08-22-2012, 11:40 AM   #3
RUNNWLD's Avatar
Region: Utah
Does it matter which isos you take out if you only take 1 out and what's the difference of you take 1 out then both?
Old 08-22-2012, 12:28 PM   #4
I took out both of mine
Old 08-22-2012, 12:43 PM   #5
RUNNWLD's Avatar
Region: Utah
Do you have the h&r super sports?
Old 08-22-2012, 12:44 PM   #6
Re: Isos with h&r springs
on a solid rear axle car you may hear noises from not having isolators in the rear, but the front is ok. H&R race is rather low to begin with, I left one out in the front and left both in the rear (all OEM isolators)
Old 08-22-2012, 12:51 PM   #7
RUNNWLD's Avatar
Region: Utah
The only thing is that the h&r ss still have a little bigger gap it the wheel wells in the back so I was thinking maybe just take the isos out In the back but does it really make a difference in lowering it? Also should I take both out or just one? I want it to sit even?
Old 08-22-2012, 12:55 PM   #8
you can take one out or both but you may get noise out back from metal/metal sounds as the spring bounces around~ just FYI
Old 08-22-2012, 01:06 PM   #9
RUNNWLD's Avatar
Region: Utah
What would look better both or 1 out? And I will be taping with electrical tape and greasing them?
Old 08-23-2012, 12:19 AM   #10
RUNNWLD's Avatar
Region: Utah
Would it look stupid with the oem spring isos in the front with h&r ss and take out the bottom isos in the back to make it sit more even or should I take both out back and 1 in front? Opinions please.
Old 08-23-2012, 01:30 AM   #11
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I would probably leave the rears in, and remove the front isos. I think the H&R SS lower the rear a bit much to begin with. Just my 2 cents.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 08-23-2012, 07:06 AM   #12
Lorraine's driver
ab_mach1's Avatar
Will the springs settle some after a week or a month? If so, maybe you should wait and see where it settles and adjust from that point.
Instagram: @ab_mach1
Old 08-23-2012, 07:11 AM   #13
Horseplay's Avatar
this might explain the noise i hear in the rear section of my car. how do i find out if im missing them in the rear ?
Low2v
Old 08-23-2012, 08:56 AM   #14
Lorraine's driver
ab_mach1's Avatar
They should be rubbery looking pads or cups on the top and bottom of your springs. You might be able to see them with a flashlight without jacking it up.
Old 08-23-2012, 09:46 AM   #15
Horseplay's Avatar
do u got a pic of how they look on the car by any chance
Low2v
Old 08-23-2012, 10:03 AM   #16
Lorraine's driver
ab_mach1's Avatar
They should look similar to the ones on the right spring.
Old 08-23-2012, 10:05 AM   #17
Horseplay's Avatar
thanks man i appreciate it. ima see if i can spot them. can i see both the top and bottom iso without jacking the car?
Low2v
Old 08-23-2012, 10:31 AM   #18
Lorraine's driver
ab_mach1's Avatar
I can't remember for sure, but you would have to jack it up too high, if you did.
Old 08-23-2012, 10:33 AM   #19
Horseplay's Avatar
maybe i should just buy a new set of iso's and get that over with
Low2v
Old 08-23-2012, 10:36 AM   #20
Lorraine's driver
ab_mach1's Avatar
You prolly want to confirm that the iso's are indeed the source of the noise you hear before dropping some dough.
Old 08-23-2012, 10:40 AM   #21
Horseplay's Avatar
any other idea what the noise might be
Low2v
Old 08-23-2012, 03:21 PM   #22
RUNNWLD's Avatar
Region: Utah
If i use the stock isos with the h&r ss springs how low do you think I will go?
Old 08-23-2012, 03:23 PM   #23
Horseplay's Avatar
do u wana keep ur isos?
Low2v
Old 08-23-2012, 03:28 PM   #24
RUNNWLD's Avatar
Region: Utah
Well the h&r ss springs seem like the back has a more gap in the back than the front. So I was thinking about just removing 1 in back to have it look even? What you think or leave the stock in? Or take both out in front one in back or both in back 1 in front? Haha sorry it's a lot of questions?
Old 08-23-2012, 04:21 PM   #25
I have the H&R SS I'm pretty sure my iOS are out.
ID:	65237   Click image for larger version
Ryan7racin is offline   Reply With Quote
Old 08-23-2012, 05:27 PM   #26
RUNNWLD's Avatar
Region: Utah
So if I didnt have the isolators out how low would the h&r ss springs be with just the oem isolators?
Old 08-23-2012, 07:52 PM   #27
Just dont use them.. Top or bottom.. Balls to the wall dont be scared its not that hard to reinstall them.
Old 08-23-2012, 09:08 PM   #28
RUNNWLD's Avatar
Region: Utah
What is the difference if you take 1 out or both?
Old 08-23-2012, 09:12 PM   #29
Lorraine's driver
ab_mach1's Avatar
Prolly be just a bit lower without both. This would be hard to measure IMO. I'm sure the spring compresses the Iso a little, so seems like it would not even be a 1/4".
Old 08-23-2012, 09:55 PM   #30
RUNNWLD's Avatar
Region: Utah
So its not worth it really to take them out? Also if someone can please answer how low would the super sports be with the regular spring isolators?
Old 08-24-2012, 03:31 AM   #31
Lorraine's driver
ab_mach1's Avatar
I'm not sure how much lower the SS's will take your car. But I personally would not remove any of my spring iso's on my car. They are there for dampening the impact between the spring and the car. That's IMO. Plus, I would not want to hear any metal on metal noises when I hit bumps.
Old 08-24-2012, 05:43 AM   #32
RUNNWLD's Avatar
Region: Utah
Yeah I might not take them out I just hope they give me a good noticeable drop!!
Old 08-24-2012, 07:04 AM   #33
I Have H&R without ISOs and good drop
Old 08-24-2012, 07:05 AM   #34
RUNNWLD's Avatar
Region: Utah
Does it squeak or anything? Did you put tape or anything instead of the isolators?
Old 08-24-2012, 07:42 AM   #35
Rm360's Avatar
The difference between using the iso's or not is a 1/2" , to be honest 9 out of 10 people won't even notice the difference , if you want to get as low as possible don't use them and use tape,a bike inner tube, a piece of rubber hose, whatever you are just preventing metal to metal contact. Anytime you start to mod the car you are gonna get squeaks , rattles it comes with doing mods you just have to accept it , you can prevent the springs from making noise all you want throw a set of aftermarket control arms on there and let the squeak fest begin
04:59 AM
