Diesel noise - Mustang Evolution
Old 08-22-2012, 04:21 PM   #1
Diesel noise
Ever since I got my auto 04 gt the engine makes a slight ticking noise which I heard is normal for the 4.6 and it sounds like a diesel. I've also cracked the stock intake manifold twice. I've already put a whole new timing set on. Any ideas??
---------- Post added at 06:21 PM ---------- Previous post was at 06:20 PM ----------
It only happens when idling
Mgsgreystang is offline   Reply With Quote
Old 08-22-2012, 04:48 PM   #2
Voltage258's Avatar
Region: Utah
Could be a exhaust leak, but normally It will get louder when you accelerate. Or it could be a lifter or something. How many miles are on it? Any mods like headers or anything?
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 08-22-2012, 05:00 PM   #3
I have 65k. The only mod that I know of is a cai
Old 08-22-2012, 05:27 PM   #4
Voltage258's Avatar
Region: Utah
Anyway you could get a video of the noise?
Old 08-22-2012, 06:09 PM   #5
Ill try to put one up in a few
---------- Post added at 07:53 PM ---------- Previous post was at 07:29 PM ----------
---------- Post added at 08:09 PM ---------- Previous post was at 07:53 PM ----------
And oil was just changed last Saturday. Royal purple
Old 08-22-2012, 06:59 PM   #6
Re: Diesel noise
If you take the oil filler cap off while its running ,,and put ur hand over it does it suck ur hand in with vacuum? Is it misfiring or skipping ??
mymustang is offline   Reply With Quote
Old 08-22-2012, 07:05 PM   #7
I'll check the oil fill cap in the am but I just did plugs a couple weeks ago I don't think it's missing but you can hear a backfire every do often
---------- Post added at 09:05 PM ---------- Previous post was at 09:03 PM ----------
Sometimes it will hesitate and bog a little when I really get on it and sometimes it will run great but it always make that noise at idle
Old 08-23-2012, 04:17 AM   #8
I checked the oil fill cap. It dosnt suck my hand in vacuum
Old 08-23-2012, 06:22 AM   #9
jjsg09's Avatar
It's sounds just like mine did I changed the Pcv and hose with brand new ones from latemodelrestorations.com and fixed it. It definitely sounds like a vacuum problem.
Old 08-23-2012, 09:01 AM   #10
I'll look into that. I was also thinking it might have something to do with the dorman intake manifold that keeps cracking
Old 08-23-2012, 10:25 AM   #11
TopgearGT's Avatar
Ya it sounds like a vacuum problem to me... the diesel noise is a little weird though.
http://www.mustangevolution.com/forum/users/25023-albums2837-17413.jpg
CSVT and 02 GT!
TopgearGT is offline   Reply With Quote
Old 08-23-2012, 10:55 AM   #12
Lorraine's driver
ab_mach1's Avatar
Re: Diesel noise
Yup, maybe the noise is cause of the rough idle and the vacuum sound (wherever it's leaking) together.
Instagram: @ab_mach1
Old 08-23-2012, 12:01 PM   #13
Re: Diesel noise
Wish i could help but I can give you some advice to find the leak. What I do is get a can of brake cleaner and lighty spray around areas where they might be a leak for example vac lines, intake, etc. If the car reacts then there is a leak, just dont spray on things that might ignite the brake cleaner or you will be on here asking whats the best hair grower lol. Thats how I do it esp when installing a new intake and CAI....good luck.
southernstang00 is offline   Reply With Quote
Old 08-23-2012, 12:53 PM   #14
I'll try spraying around a little. I might end up having to change the intake.
Old 08-23-2012, 03:57 PM   #15
Re: Diesel noise
alrighty just let us know what fixed it
Old 08-23-2012, 04:21 PM   #16
05.BCA.Mach1's Avatar
Re: Diesel noise
Have you checked the donut gasket? My boyfriend went through 3 in his 2000 GT
05.BCA.Mach1 is offline   Reply With Quote
Old 08-23-2012, 08:04 PM   #17
Black05gt's Avatar
It's probably cam phazers, I had a 05 expedition that made the same noise, dealer fixed it under warranty, fixed the noise. it had a 5.4L but 4.6's have them too!
Black05gt is offline   Reply With Quote
Old 08-24-2012, 05:14 AM   #18
I'll have to look at the donut gasket. I can't see or smell any smoke around there. And I think only the 05+ 3v have cam phasers
Old 08-26-2012, 10:11 AM   #19
Re: Diesel noise
I deg agree because my 4.6 doesnt have cam phasers.
Old 08-26-2012, 11:49 AM   #20
infamous281's Avatar
Sounds like exhaust leak or internals are messed up
Old 08-26-2012, 01:10 PM   #21
I have the same noise. Could be the injectors fireing. Ima check for vacume problems though.
Cdbformula is offline   Reply With Quote
Old 08-31-2012, 05:59 AM   #22
daddydigest's Avatar
Any update? Mine makes the same noise!
daddydigest is offline   Reply With Quote
06:19 PM
