Idle Issues - Mustang Evolution
Old 08-22-2012, 07:08 PM   #1
Idle Issues
My 2004 GT has 143000 miles and has always run Great ! Just recently, it started to die upon idle, (braking), but only when warmed up. I can keep it running by hitting the gas, when I see the tach start to jump erratically and drop below 500, but I hear a "clunk" sound when I do that.
Ideas?? Suggestions? Thoughts?
crmrn1 is offline   Reply With Quote
Old 08-22-2012, 08:49 PM   #2
Mfore33's Avatar
I've had this problem before. Change your IAC module. It's on front of the throttle body. Has 2 screws and the 1 inch vacuum line
Old 08-23-2012, 12:02 AM   #3
infamous281's Avatar
Most likely IAC.. Its expensive too
Old 08-23-2012, 01:40 AM   #4
Silver Pony's Avatar
Try cleaning it with carb cleaner first. I've had this before and it solved the problem. Just spray the **** out of it.
Silver Pony is offline   Reply With Quote
Old 08-23-2012, 05:08 AM   #5
Re: Idle Issues
What is the IAC ?
Old 08-23-2012, 05:27 AM   #6
It's not me, it's you.
primer2tone's Avatar
What is the IAC ?
Idle air control module.
Old 08-23-2012, 05:39 AM   #7
taylor98gt's Avatar
The Iac isn't that expensive I picked one up at autozone for 50 dollars. That's not.bad to get it.running.right again
taylor98gt is offline   Reply With Quote
Old 08-23-2012, 08:00 AM   #8
Mfore33's Avatar
It's the thing with a C cell size can and a triangle mounting bracket at the back and 1 hose attached
Old 08-23-2012, 08:52 AM   #9
Lorraine's driver
ab_mach1's Avatar
If its not in terrible shape, you can clean it to get you by until you have enough to buy a new one. Carb or throttle body cleaner will work. Just don't get the connector wet.
Instagram: @ab_mach1
Old 08-24-2012, 10:55 AM   #10
Re: Idle Issues
Thanks a whole lot all !!
I really appreciate it !!
I am sure not a mechanic and dont pretend to know a whole lot, so all the help is greatly appreciated !!
01:45 AM
