check engine bogging issues - Mustang Evolution
Old 08-22-2012, 09:17 PM   #1
98GTCONV's Avatar
I was driving down the road when I notice my check engine turns on. Nothing was acting up at the time. 5 more miles down the road, mustang started sputtering, around 45 mph it was shaking and sounded like it wanted to cut off. So I pulled over, turned it off and back on, made sure plugs were tight and pressed the gas. It revved fine but as it came down below 1000 rpms it sputtered and seemed like it would turn off but didn't...sry for the long explanation. But what do you think it could be? Similar thing happened to you? Thanks in advance
98GTCONV is offline   Reply With Quote
Old 08-22-2012, 09:30 PM   #2
maldog's Avatar
Region: Nevada
Re: check engine bogging issues
Check your codes and tell us what they are?
---------- Post added at 08:30 PM ---------- Previous post was at 08:29 PM ----------
If you do not have a code reader? Take it to auto zone for a free check.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-22-2012, 09:36 PM   #3
98GTCONV's Avatar
That's what ill do tomorrow. Just wondering if anyone has ever experienced this and what it ended up being.
Old 08-22-2012, 09:53 PM   #4
runvsofthisbull's Avatar
Well sounds like what happened to my 3.8L when the coil pack went bad. I would maybe assume you also have a bad coil, but who knows until you get the code read for sure.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 08-22-2012, 10:54 PM   #5
TopgearGT's Avatar
Hah i just started experiancing the same thing just now in my buddies G35 and his CE light just came on! Could it be an air intake issue?
http://www.mustangevolution.com/forum/users/25023-albums2837-17413.jpg
CSVT and 02 GT!
TopgearGT is offline   Reply With Quote
Old 08-23-2012, 11:20 AM   #6
98GTCONV's Avatar
Went to advance auto. Plugged it up and said it was a bad o2 sensor.
Old 08-23-2012, 03:06 PM   #7
98GTCONV's Avatar
Shop tells me I need it synonymous tuned
---------- Post added at 04:06 PM ---------- Previous post was at 04:05 PM ----------
*dyno ( spellcheck)
Old 08-23-2012, 03:14 PM   #8
05MUSTANG4.0L's Avatar
Mine did the same thing, then in my way home from buying an alternator it dies on a green lighty
05MUSTANG4.0L is offline   Reply With Quote
check engine
10:04 AM
