engine swap? - Mustang Evolution
Old 08-23-2012, 05:01 PM   #1
98GTCONV's Avatar
engine swap?
Im looking into swapping my 150k 98 4.6 for a 14k 00 4.6. Im working with about 3k. After I buy the engine id have around 1,600. Im not sure if I would need any other parts since the engines are very similar? I just need a list of what else ill need, if anything, to take to the shop. And an estimate from anyone who's swapped before on what the shop bill was?
98GTCONV is offline   Reply With Quote
Old 08-23-2012, 05:38 PM   #2
01bullitt's Avatar
for that about of money rebuild your block put pi heads and some bolt ons have a higher compression fresh motor. you can do that for less than 3k
01bullitt is offline   Reply With Quote
Old 08-24-2012, 07:09 PM   #3
I would go with rebuilding yours.
Cdbformula is offline   Reply With Quote
Old 08-24-2012, 07:32 PM   #4
Mile high JDF's Avatar
I would think that would be it. It's possible that you could need the PCM but I'm not sure. Just get a quote from a local shop as to the price of install. Are you mechanically inclined at all?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-24-2012, 07:49 PM   #5
98GTCONV's Avatar
Somewhat. Just started school for it so hopefully within the next 2 years I wont need a shop!
Old 08-24-2012, 09:29 PM   #6
Pulling an engine is fairly simple.
Old 08-24-2012, 10:15 PM   #7
98GTCONV's Avatar
Anybody ever swap a aode with a t45? Any complications that were ran into? What did the bill come out to be if u went to the shop?
Old 08-24-2012, 11:09 PM   #8
infamous281's Avatar
A Pretty Penny !
If you dont have the right tools dont do it and mess something up.
Id just build your current block and do a tranny swap . NPI motors have the best Compression
Old 08-24-2012, 11:19 PM   #9
98GTCONV's Avatar
Well I found a kit with everything id need. It would be that bad? I swapped my old 4r70w for a newly rebuilt one. Took a few days but was fairly simple. Im talking about taking it to a shop tho. It would be just the cost if labor
Old 08-24-2012, 11:23 PM   #10
Put a 3000-3500 Stall while your in there !
---------- Post added at 12:23 AM ---------- Previous post was at 12:23 AM ----------
Couple hundred
Old 08-24-2012, 11:32 PM   #11
98GTCONV's Avatar
$1400 kit and a couple hundred puts me under 2k
Old 08-25-2012, 12:24 PM   #12
charlie03fastGT's Avatar
In my area depending on the shop the bill for a straight up swap usually runs anywhere from 400-650 on labor only.
charlie03fastGT is offline   Reply With Quote
Old 08-25-2012, 01:50 PM   #13
Stockish302's Avatar
Why not do the 5.4 2v and just build that while your current engine gives out. A 5.4 with some tfs2 cams makes good power and torque.
BBK cai, 96 tbird maf housing, BBK 70mm TB, TFS intake manifold, BBK shortys, bassani off road X pipe, Flowmasters with turndowns
If any one is willing to donate parts to the Make Joe's Mustang Faster that Corvettes Foundation, donations will be gladly appreciated
Stockish302 is offline   Reply With Quote
Old 08-25-2012, 07:17 PM   #14
TopgearGT's Avatar
Re: engine swap?
I just did a tranny swap and that cost me 365. It shouldn't be much more then that since you wont have to go through the trouble of unbolting a tranny just pull the old engine and tranny out and put the new ones in!
http://www.mustangevolution.com/forum/users/25023-albums2837-17413.jpg
CSVT and 02 GT!
TopgearGT is offline   Reply With Quote
10:38 PM
