Brake lights wont come on - Mustang Evolution
Old 08-24-2012, 07:03 PM   #1
I Changed the stop light switch. Still won't come on
caulderk is offline   Reply With Quote
Old 08-24-2012, 07:11 PM   #2
Venomouz831's Avatar
Maybe a fuse? Pull em out n see if ones fried
)02 Gt, Founder of WE2G
Old 08-24-2012, 07:20 PM   #3
I just checked all fuses under steering wheel and hood. The lights in the back come on but the brake lights won't
Old 08-24-2012, 07:51 PM   #4
Rm360's Avatar
Did you check the bulbs?
Old 08-24-2012, 08:03 PM   #5
I did. All of a sudden one day I couldn't put it in gear. That's when the brake Lites stopped coming on. Now I have to use a screwdriver to put it in gear.
Old 08-24-2012, 09:27 PM   #6
Rm360's Avatar
Do you have a auto or manual trans ? And how are you using a screwdriver to put it in gear ??
Old 08-24-2012, 11:14 PM   #7
infamous281's Avatar
Lol Dang.. You porbably busted a switch or relay
Old 08-25-2012, 12:48 AM   #8
1slosix's Avatar
Re: Brake lights wont come on
i know what this is...the shifting issue is a dead giveaway
---------- Post added at 01:48 AM ---------- Previous post was at 01:45 AM ----------
this has happened on all 3 mustangs i've owned...there are two wires that lead to the brake light switch...they go into a little plastic box that just pulls off of the switch. cut the wires about 5" from the box and pull the box from the switch...the best way to fix this now is to splice in new wire with female ends (like audio crimp ends)...now just slide the female ends over the brake light switches males ends...use female ends that'll be a tight connection. you sir now have functioning lights and your shifter will be smooth once more.
i'll take pics in the AM for you if you'd like
Old 08-25-2012, 01:59 AM   #9
Please if you don't mind. Would that have anything to do with the brake ligts?
Old 08-25-2012, 11:02 AM   #10
---------- Post added at 11:02 AM ---------- Previous post was at 10:57 AM ----------
Yes will u please send me the pics
Old 08-25-2012, 12:31 PM   #11
1slosix's Avatar
i took the wrap i had off so you could see the splice...just make sure when you put the female ends on that you put the wires to the right male end...so what i do is take a pic of it wired up before you cut anything....that way you can run the correct color to the right one
should take you 15 minutes to get back on the road right
Old 08-17-2013, 06:17 PM   #12
MidnightBlueGT's Avatar
Old thread brought back sorry....buddy of mine took out tails to tint and had an issue with leaving park and brake lights, took out all fuses and one was blown and replaced, now leaves gear. Just brake lights wont work still. Any ideas?
Old 05-15-2014, 11:07 AM   #13
Brake light problems
Hey I'm new to the forum I read this 🔼. Would you mind send me the same picture
martianman19 is offline   Reply With Quote
Old 05-15-2014, 12:15 PM   #14
Mile high JDF's Avatar
Umm 1slosix hasn't been on since last year. Can you not just copy the pic?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-15-2014, 12:43 PM   #15
Yeah I just wanted to see the color of the wires
02:17 PM
