Jlt intake question? - Mustang Evolution
Old 08-25-2012, 12:37 PM   #1
RUNNWLD's Avatar
Region: Utah
If I got the jlt intake would I have to get a tune when I purchase it or can I get it, install it and then get a tune later?
RUNNWLD is offline   Reply With Quote
Old 08-25-2012, 01:53 PM   #2
Voltage258's Avatar
Region: Utah
You won't need a tune. Just disconnect the battery while you put it on. And once you put it on and reconnect the battery the computer will relearn its self and compensate for the intake.
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 08-25-2012, 02:55 PM   #3
RUNNWLD's Avatar
Region: Utah
Okay sweet thanks man!!!
Old 08-25-2012, 03:12 PM   #4
Voltage258's Avatar
Region: Utah
Re: Jlt intake question?
No problem
Old 08-25-2012, 03:57 PM   #5
Shelby09's Avatar
U need a tune
Shelby09 is offline   Reply With Quote
Old 08-25-2012, 04:10 PM   #6
RUNNWLD's Avatar
Region: Utah
I'm thinking I might just do the intake and tune all at the same time!(:
Old 08-25-2012, 04:11 PM   #7
Shelby09's Avatar
Good man
Old 08-25-2012, 04:43 PM   #8
Voltage258's Avatar
Region: Utah
You do not need a tune. But if you are planning on doing a tune someday as well and have the money you might as well get a tuner with you intake.
Old 08-25-2012, 04:46 PM   #9
Shelby09's Avatar
If your intake is bigger than the factory one ur MAF will not read right.. Ur factory computer will not compensate for that by unhooking ur battery
Old 08-25-2012, 04:59 PM   #10
Voltage258's Avatar
Region: Utah
It won't be as effective as if it were tuned. But it's not like it's an absolute need. His car is not going to run poorly or miss or loose power if he does not get It tuned. It won't have any bad effects on the car.
Old 08-25-2012, 05:04 PM   #11
Shelby09's Avatar
Do what u want
Old 08-25-2012, 05:33 PM   #12
Lorraine's driver
ab_mach1's Avatar
Originally Posted by Shelby09 View Post
U need a tune
Nope ya don't.
Instagram: @ab_mach1
Old 08-25-2012, 05:34 PM   #13
Shelby09's Avatar
Do what u want
Old 08-25-2012, 05:39 PM   #14
Lorraine's driver
ab_mach1's Avatar
You will only need a tune if you get a larger MAF, TB, intake, or a combo of these. You'll need a tune if you get an aftermarket H or X pipe, mainly to take advantage of this mod and to shut off the CEL. Obviously, a tune will make a little more HP and throttle response, but as long as you perform the idle re-learn (which also sets the fuel trim) these mods will not hurt your car.
Old 08-25-2012, 05:58 PM   #15
RUNNWLD's Avatar
Region: Utah
Okay thanks and also there is a guy selling a sct tuner for 200 bucks and if I bought it will I still get free tunes for life by bama and how to I go about setting the tuner up for my car?
Old 08-25-2012, 07:56 PM   #16
2003mustangGT's Avatar
If the tuner is married to the other car you wil have to send it to bama to have it taken off.
2003mustangGT is offline   Reply With Quote
Old 08-25-2012, 08:00 PM   #17
RUNNWLD's Avatar
Region: Utah
Alright I'm just going to buy a tuner seperate because, the jlt intake combo with tuner is just the flat black one. I'm going to order the one to Match my car color.
08:32 AM
