need some help. - Mustang Evolution
Old 08-25-2012, 10:23 PM   #1
charlie03fastGT's Avatar
need some help.
My 03 GT makes a whining/humming noise during quick acceleration and turning at any speed. I believe it shld be from differential which I checked today for appropriate fluid level. I managed to put in half a quart so I'm assuming that's all it needed cuz I did spill a good amount. I didn't have the car on a lift considering I was at home at hoqme
---------- Post added at 11:23 PM ---------- Previous post was at 11:21 PM ----------
I was at home I used jack stands to hold up the rear end. I drove after checking fluid and didn't hum so much at acceleration but still on turns. Any one have any pointers on what might be wrong. Thanks
charlie03fastGT is offline   Reply With Quote
Old 08-25-2012, 11:28 PM   #2
irishn8's Avatar
If adding some fluid helped, try changing the fluid completely. May have gone bad. If that doesn't help then check wheel bearings.
Old 08-26-2012, 10:15 AM   #3
Checked the bearings they seem good. Ima definitely just change the fluid completely. See wat result I get
09:10 AM
