DDM hid lights - Mustang Evolution
Old 08-26-2012, 01:08 AM   #1
BeasGT's Avatar
DDM hid lights
I have no clue what and how to order someone help please!
BeasGT is offline   Reply With Quote
Old 08-26-2012, 11:40 AM   #2
02PONY's Avatar
I'd just order from eBay you'll get your kit in a matter of days It'll be weeks before u get your ddm kit and it's the same as the cheap eBay kits
02PONY is offline   Reply With Quote
Old 08-26-2012, 11:40 PM   #3
1slosix's Avatar
Re: DDM hid lights
what would you like to know...i've been dealing with DDM for years
---------- Post added at 12:40 AM ---------- Previous post was at 12:39 AM ----------
you'll need 9007 bulbs...either a single beam kit or hi/lo kit...that's up to you
i run a 6k because i like a tinge of blue, but if you want white then look into a 4700
Old 08-27-2012, 01:09 AM   #4
BeasGT's Avatar
Everything about hids.
I want the hi/low kit
Should I go with 35w or 55w?
Old 08-27-2012, 03:28 AM   #5
MachMan1017's Avatar
Look at the charts from what colors you want
..3000k(yellow) 6000k is closest to white( which is what I have because it gives you the most road visibility.) And it goes up to like 12,000k which I believe is purple, and even higher.
And I went with the 55 watt ballast, just so I could emit the brightest light out of my HIDs.
Also, to find what bulbs you need, they have a site you can click on to put in your car info to get your bulb number( if you don't already know.)
Hope this helps.
MachMan1017 is offline   Reply With Quote
Old 08-27-2012, 08:02 AM   #6
04Mstng.GT's Avatar
Do they have a combo kit for headlights and fog lights? HID
04Mstng.GT is offline   Reply With Quote
Old 08-27-2012, 09:49 AM   #7
jjsg09's Avatar
Does anybody really know if you need to have the high low beam set? Has anyone ran it a problem with just having the low beams?
Old 08-27-2012, 09:59 AM   #8
RUNNWLD's Avatar
Region: Utah
What does it mean high beam low beam? Also do you need slim ballast?
RUNNWLD is offline   Reply With Quote
Old 08-27-2012, 11:43 AM   #9
As far as a combo, are you meaning at a discounted price? Because they sell your fogs, lows and highs but you have to pay for each set. And as far as slim ballast go... Honestly not to sure... Mine came with the slim ballast ...
Old 08-27-2012, 12:03 PM   #10
04Mstng.GT's Avatar
Yea that's what I was asking I didn't know if I had to buy each one separate
Old 08-27-2012, 02:46 PM   #11
Arron's racecar's Avatar
Region: Nevada
I have the 8000k set from DDM but I had the high low kit before I switched to my aftermarket headlights. Because I had the harness that came with the hi/low kit I was able to modify it so that I could have my HIDs for low beams and use the standard H1 bulbs that came with the headlights for high beams. The standard bulb type for the cars factory lights are 9006's I believe. So if u plan on getting aftermarket projector headlights then all you would have to do is buy the bulbs to fit them. Mine use a H1 style. Hope this helps!
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 08-27-2012, 10:10 PM   #12
1slosix's Avatar
Re: DDM hid lights
ok for me i just run a low beam setup....i use to have a hi/lo kit but honestly i never even needed the high beams even with my lights aimed super low.
i run the standard DDM raptor kit...i've had both the 55w and 35w kit's...in an oem housing 35w's are good and bright...in a tinted housing i'd reccomend 55ws
Old 08-27-2012, 10:25 PM   #13
jjsg09's Avatar
So u drive around with 35w in both headlight and fogs what color do u have?
Old 08-30-2012, 12:08 AM   #14
BeasGT's Avatar
Do I have to order 2 kits? One for the headlights and one for the fogs? Or what?
Old 08-30-2012, 07:01 AM   #15
Mfore33's Avatar
I ordered the raptor 35 watt 890 bulb kit for the fogs and the 55 watt 9007 bulb low beam only and they work just fine
Old 08-30-2012, 07:19 AM   #16
Re: DDM hid lights
I ordered a set of DDM for my wife's 2011 Edge (can see if they also fit yours as I have them uninstalled)
you just need the bulb size, and go with 65w for headlights 35w for fogs~
you want to spend 12.50 for the harness as well.
You want slim ballasts FYI. Its rather easy to install for some reason the edge would have the lights cut out, not sure why~ probably didnt like the hook up for some reason so I just removed them.
Old 12-05-2012, 09:43 PM   #17
BeasGT's Avatar
How hard is it to install? Is there a video on installing them?
Old 12-05-2012, 10:08 PM   #18
RUNNWLD's Avatar
Region: Utah
No they are really easy to install it took me about 1 hr and yeah just on YouTube and type in (mustang hid install) its by xenon.
Old 12-05-2012, 10:10 PM   #19
1slosix's Avatar
about 15 mins a side at least for me...but i've done it a few times
carving corners like a boss
Old 12-05-2012, 10:33 PM   #20
BeasGT's Avatar
Is it plug and play?
Old 12-05-2012, 10:35 PM   #21
1slosix's Avatar
yes and no...they come with a female harness in that'll connect to your oem male headlight harness...the only thing that you have to do is slide the wire ends through the female harness....it's pretty self explanitory when you see it for the first time
Old 12-05-2012, 11:04 PM   #22
BeasGT's Avatar
I just got my kit in today.
So ill try it tomarrow.
What's the worst than can happen?
Old 12-05-2012, 11:05 PM   #23
1slosix's Avatar
if you wire them up wrong they won't turn on....in that case just play around with the wires till you get it right. the ground wire is pretty clear on both the oem harness and the ddm one so that's good if you need me to tomorrow i'll pop my headlights off and snap pics if you get in a bind.
Old 12-05-2012, 11:06 PM   #24
BeasGT's Avatar
Sounds good! Thanks!
Old 12-06-2012, 03:03 PM   #25
BeasGT's Avatar
Old 12-06-2012, 07:32 PM   #26
Mfore33's Avatar
Is it worth it to get the hi/lo kit or just get the low kit
Old 12-06-2012, 08:38 PM   #27
BeasGT's Avatar
Old 12-06-2012, 09:11 PM   #28
schmitty426's Avatar
Are those tinted headlights and fogs?
schmitty426 is offline   Reply With Quote
Old 12-06-2012, 09:17 PM   #29
BeasGT's Avatar
Headlights yeah fogs no.
Old 12-06-2012, 09:24 PM   #30
Ok are u running different watts for the headlights vs the fogs?
Old 12-06-2012, 09:40 PM   #31
BeasGT's Avatar
Yeah 55w 6k headlights
35w 6k fogs
Old 12-06-2012, 09:49 PM   #32
35w 6k fogs
Sweet looks good!
Old 12-06-2012, 11:04 PM   #33
BeasGT's Avatar
Sweet looks good!
Thank you!
Old 12-07-2012, 07:32 AM   #34
jjsg09's Avatar
35w 6k fogs
I like!
Old 12-07-2012, 07:39 AM   #35
jjsg09's Avatar
Originally Posted by jjsg09 View Post
I like!
Mine from DDM 5k 55w heads and 5k 35w Fogs
01:22 AM
