Metal shavings on oil pump screen - Mustang Evolution
Old 08-27-2012, 12:38 PM   #1
I just dropped the oil pan to replace the gasket and I saw this. Its a 98 cobra with 74000 miles on it. I know they will have some shavings so here is the question, is this normal?
ID:	65806   Click image for larger version
southernstang00 is offline   Reply With Quote
Old 08-27-2012, 01:20 PM   #2
infamous281's Avatar
Doesnt look good damn
Old 08-27-2012, 02:53 PM   #3
Re: Metal shavings on oil pump screen
yea, but it was chunks though just shavings.....they were thinner then a finger nail clipping. The engine is running really strong and no issues.
Could it just be from when it was broken in and never cleaned off? The oil plug didnt have anything either.
Old 08-27-2012, 06:03 PM   #4
onesickstang01's Avatar
Ive had hundreds of motors apart. Everything from dirtbikes to semi trucks and ive never seen shavings like that. That looks like drill bit shavings. Has your oil pan been drilled for a supercharger/turbo drain tube?
onesickstang01 is offline   Reply With Quote
Old 08-27-2012, 08:08 PM   #5
Onesickstang01, Nope the car is all stock and no holes in the oil pan. Not using oil either....
Old 08-27-2012, 08:54 PM   #6
Mile high JDF's Avatar
Does it have an aftermarket plug? Those look kinda like threads.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-27-2012, 11:18 PM   #7
ya know, since you say that it actually does because I went to grab the same wrench I use on my GT and it didnt fit. While I was gone my dad took it somewhere to get the oil changed, maybe they stripped the plug and re-threaded it with a new plug? Those shavings where kinda fresh.
Old 08-27-2012, 11:35 PM   #8
That's probably it then.
Old 08-28-2012, 05:30 AM   #9
Lorraine's driver
ab_mach1's Avatar
I think it's normal IMO. I bet that's the first time the pan was dropped. Plus, as you said, it runs strong. Seems like there would be clues from running it, that would lead you to believe otherwise. I could see how that would make you pucker up though!
---------- Post added at 07:30 AM ---------- Previous post was at 07:28 AM ----------
Haha! I really should start reading through these threads! I believe you guys found the culprit.
Instagram: @ab_mach1
Old 08-28-2012, 11:27 AM   #10
yeah I agree,
---------- Post added at 12:27 PM ---------- Previous post was at 12:26 PM ----------
Yea it was the first time it was dropped but I agree there should be some signs if there was a problem. Haha its cool, sometimes I dont read all of the replies either but if it isnt the plug then its prolly from where the engine was broken in and the screen never cleaned
07:04 PM
