jammed cd changer - Mustang Evolution
Old 03-18-2008, 10:47 AM   #1
jammed cd changer
well as most of you may know the 6 disc changers are bad to stick and this time i can't even see the cd to try to pull it out. so what should i do?
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 03-18-2008, 10:52 AM   #2
Re: jammed cd changer
I had the same thing happen and found an old thread on here about how to get it out.
I took a real thin screw driver and just put a little pressure where the CD should be...as I couldn't see it either. The thread said you could use another CD as well....just something thin enough to get inside and apply pressure to the top of the CD.
It came right out for me...so now I have a small screw driver in my arm rest at all times.
Old 03-18-2008, 10:56 AM   #3
Y2E0L0L5OGWT's Avatar
My '03 used to do it with Mach 6-disc...I would just use a butter knife or something with a very flat blade...as PV said above, just slide the blade in above the CD area, push down on it with a little pressure and it should slide out....
Old 03-18-2008, 11:43 AM   #4
i'll try a butter knife. i've pushed a cd in there but nothing happened this time, that's worked for me before. i called the ford dealer and they told me that burnt cd's could make it go bad. looking at some aftermarket systems now since i've thought about satilite radio.
Old 03-18-2008, 12:18 PM   #5
mine sticks on cd's with cover stickers on them, dont use those
Old 03-18-2008, 07:21 PM   #6
jimmy_beaner's Avatar
Region: Iowa
when my finally broke for good (without the CD trick)... I had the gf's mom fix it for me. She took it apart and removed the CD's and it worked fine again, even though the CD's still stick on the way out. But when it fubars really bad and won't play anything, it's nice to at least be able to put a CD in and play it.
Old 03-28-2008, 11:45 AM   #7
well i stoped working on my cd player for a while and last night i noticed that the cover was back up and i pushed the cd player and it started working again. strange but glad.
Old 04-01-2008, 11:04 AM   #8
I have a similar problem with my Mach 600 changer.
I can't put a disc in or eject anything out.
I just bought the car last year and figured it was shot. Could this mean a disc is stuck in it and I should try the suggestions above?
Paddy21 is offline   Reply With Quote
Old 04-01-2008, 04:03 PM   #9
slvr2000stang's Avatar
The wife's Focus 6 disk got stuck. I removed it opened the cover and had to re align the CD's in there.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 04-03-2008, 06:57 AM   #10
Wow, ah ha I thought I was the only one with this problem. I have a 2001 Ford Mustang GT. :p
My girlfriend usually un-jams the CD and pulls it out by sliding a key in the disc tray.
It's ridiculous though as sometimes it scratches the CD but it's the only we've figured out how to get the jammed CDs out!
Pontiac Grand Am vs Ford Mustang anyone? :confused:
Mustang Body Kit
King Justice is offline   Reply With Quote
Old 05-08-2008, 05:53 AM   #11
It happens to me alot, I just use another CD
andres0286 is offline   Reply With Quote
Old 05-08-2008, 10:39 AM   #12
Send a message via AIM to rwboring
i think its mainly when it gets hot... when i drive back to my hometown i can make it like 4 hours till it starts and it does it EVERYTIME... just grab a CD and start pokin (i think it is always with burned ones also so i usually try to just listen to bought ones for the last few hours or dont pull the burned ones out)
rwboring is offline   Reply With Quote
F/S Mach 6 disk changer Foxone Mustang Parts for Sale and Wanted 6 09-05-2008 10:19 AM
6 disc changer messing up KyleUSAF Mustang Audio & Video 4 12-24-2006 09:32 PM
ipod + controller or mp3 changer for car? Monkey The Bar 6 01-05-2006 12:07 AM
Clarion 6-disc Changer Ken Mustang Parts for Sale and Wanted 1 10-04-2005 05:09 AM
Installing an addon CD-Changer? Shahrum Mustang Audio & Video 5 01-01-2004 09:17 PM
» Members Mustangs
Baby
Fast 97
SHADOW
SHADOW
Add your Mustang
03:02 PM
