Supercharger - Mustang Evolution
Old 09-01-2012, 03:58 PM   #1
Doe_Rae_mi's Avatar
Supercharger
Hey guys I'm looking to buy a supercharger eaton m112. I have a 2003 mustang gt will my engine be able to take it?
Old 09-01-2012, 04:09 PM   #2
ColeJohnson's Avatar
Re: Supercharger
Isn't that the stock termi s/c? If so, you'll need an adapter bracket but the engine can take it. Just be careful because that s/c produces a ton of heat.
2016 Comp Orange GT (current)
Old 09-01-2012, 07:53 PM   #3
Doe_Rae_mi's Avatar
Yep it is the stock one from the termi . And thank you!
Old 09-02-2012, 02:46 AM   #4
Just make sure your tuner does a good job and you'll want to keep your power below 400rwhp because of the cast rotating assembly.
Old 09-02-2012, 07:05 AM   #5
Doe_Rae_mi's Avatar
Itll definitely be below 400 my engine is completely stock ha
Old 09-02-2012, 12:31 PM   #6
CodyNelson's Avatar
Region: West Virgina
Re: Supercharger
To each his own...but by the time you spend the money of the Eaton and then buy the Tork Tech adapter kit you will have over 3500 in your setup and that blower does not perform well on our 2Vs. They are very ineffecient and produce a ton of heat. At 10psi you will be very lucky to break 350hp at the wheels. You would be better off to buy a good centri kit
Old 09-02-2012, 12:38 PM   #7
fresh2death's Avatar
+1 for what its worth your better off saving your money and putting it towards a better supercharger. If you're going do to it right do it right the first time.
fresh2death is offline   Reply With Quote
Old 09-02-2012, 01:50 PM   #8
CodyNelson's Avatar
I have a vortech kit for sale for $3500 in the classifieds. That's less than it would take to get the eaton kit and all the pieces you will need for it. And my kit would be perfect for a stock motor. It is also good enough to support 600hp once you build the bottom end up
05:10 PM
