Turbo blue - Mustang Evolution
Old 09-01-2012, 10:38 PM   #1
Slingblade's Avatar
Turbo blue
Does any body know about running turbo blue is stock 4.6 will it hurt it
Slingblade is offline   Reply With Quote
Old 09-01-2012, 10:46 PM   #2
ColeJohnson's Avatar
Re: Turbo blue
I'm assuming Blue is the name of your car? not bashing you at all when I say this but separating sentences will lead to a more hasty reply.
As for your question the stock 4.6 bottom end by rule of thumb is good up to about 400rwhp(although the cast crank should be good up to a little over 600rwhp, the cast rods are the weak part). Some run much more without many problems, some run less without problems. Just depends on how many times you want to roll the dice.
However, a turbo if tuned correctly and kept up with is typically safer than a supercharged system due to the fact you can stay out of boost if you drive carefully. However when boost builds it is a lot rougher on the engine because of the sudden power surge on the components.. If you keep the boost low, however, you should be ok.
If you're like me, however, you'd want to not cut corners and do it right so you'd want to get a forged rotating assembly before putting FI on.
Just some facts and opinions I've gathered over the years..
2016 Comp Orange GT (current)
Old 09-01-2012, 10:57 PM   #3
Slingblade's Avatar
No not a turbo it's a high
octane fuel
---------- Post added at 11:57 PM ---------- Previous post was at 11:51 PM ----------
octane fuel
Will running turbo blue racing fuel in stock 4.6 hurt it
Old 09-01-2012, 11:01 PM   #4
Coreyw428's Avatar
Region: Arkansas
It's really bad on the injectors, fuel pump and filter, and it will burn the o2's up... Some ppl say that it will melt the inside of the cats if you have them
Coreyw428 is offline   Reply With Quote
Old 09-01-2012, 11:06 PM   #5
Slingblade's Avatar
Thank you was thinking of running it but not now lol
Old 09-01-2012, 11:37 PM   #6
+1 I heard all these same things.
Ryan7racin is offline   Reply With Quote
Old 09-01-2012, 11:39 PM   #7
Coreyw428's Avatar
Region: Arkansas
It's loaded with lead and burns hot, I wish we could run it just cause I love the smell of it! Favorite part about goin to dragstips is cause almost all the old school carb guys run it and it fills the air lol
Old 09-02-2012, 08:11 AM   #8
Slingblade's Avatar
That's y I wanted to run it lol love the smell a guy told me that if I leaned it out that it would fine maybe like 4 gallons per hole tank of gas but I don't know
Old 09-02-2012, 09:04 AM   #9
Coreyw428's Avatar
Region: Arkansas
You might be able to do a mix and be okay, just go real light like maybe a gallon of turbo to a full tank of gas.... I definatly wouldn't dump to much in it though
Old 09-02-2012, 09:31 AM   #10
03whitey's Avatar
Racing fuel definatly burns colder feel a carb on a car with 93 octane pump gas in it and then feel one with racing fuel and then tell me which burns hotter lol, also i mix my fuel at the track ill usually leave about a quarter of a tank of 93 pump gas in my car and mix it with about 3 gallons of raceing fuel and my car runs fine! O2 sensors and every thing still working like normal!
---------- Post added at 10:31 AM ---------- Previous post was at 10:30 AM ----------
But if you do mix to much it will burn the 02s out and mess your cats up id u run them
03whitey is offline   Reply With Quote
Old 09-02-2012, 09:36 AM   #11
Shawndia's Avatar
Well I just got a 2000 v6 Mustang know where I can get a good deal on parts
---------- Post added at 09:36 AM ---------- Previous post was at 09:32 AM ----------
I just got a 2000 v6 Mustang know where I can get good parts it's in good condition I just got to get interior parts
Shawndia is offline   Reply With Quote
Old 09-02-2012, 09:51 AM   #12
www.americanmuscle.com
Old 09-03-2012, 08:44 PM   #13
Speed_Mister's Avatar
Region: Arkansas
Turbo blue does smell good
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
08:52 AM
