ac help - Mustang Evolution
Old 09-03-2012, 11:39 AM   #1
01bullitt's Avatar
ac help
2001 bulitt.
yesterday ac was fine this morning warm air checked fuses both fine.
when i turn it to ac the rpms drop like normal. help please? i dnt know anything about ac!
01bullitt is offline   Reply With Quote
Old 09-03-2012, 02:42 PM   #2
01bullitt's Avatar
i need help!
Old 09-03-2012, 03:12 PM   #3
sally2002's Avatar
Originally Posted by 01bullitt
i need help!
Have you hooked any pressure gauges to it to check the pressures
sally2002 is offline   Reply With Quote
Old 09-03-2012, 03:26 PM   #4
01bullitt's Avatar
no i havnt taking it to shop yet
Old 09-03-2012, 03:32 PM   #5
sally2002's Avatar
Another thing to look at is the wiring to your ac compressor clutch is anything wrong with it unplugged, or broken wire
---------- Post added at 09:32 PM ---------- Previous post was at 09:30 PM ----------
Also does the clutch engage
Old 09-03-2012, 05:51 PM   #6
01bullitt's Avatar
how do i check or see if clutch engages
Old 09-03-2012, 06:10 PM   #7
Mile high JDF's Avatar
Start your car and let it idle. Look at the compressor and in the center of the pulley there should be a part that isnt spinning. Turn on the A/C and it should start spinning.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-03-2012, 07:17 PM   #8
01bullitt's Avatar
thank you for info
Old 09-03-2012, 07:34 PM   #9
sally2002's Avatar
thank you for info
Let us no what's up
Old 09-03-2012, 08:01 PM   #10
Lorraine's driver
ab_mach1's Avatar
If you plan on picking up or borrowing some gauges, don't connect them while the AC is running. Trying to connect to your suction line while it's running might let air in the system. Also, use a dual gauge setup (liquid and suction line connection) as this will allow you to truly see what's going on.
Instagram: @ab_mach1
Old 09-03-2012, 08:12 PM   #11
charlie03fastGT's Avatar
Yes dual gauge setup does give out the best readings. If the clutch does engage maybe one of your Ac switches went out. One thing is don't add R134a until u know Wats going on. I see this too often where ppl over pressurized their Ac system and end up messing the whole system up.
charlie03fastGT is offline   Reply With Quote
Old 09-04-2012, 08:27 AM   #12
01bullitt's Avatar
clutch dose not engage
Old 09-04-2012, 09:16 AM   #13
If the pressure is to low and the r134a is too low the clutch won't engage. You might to fill it up some. I had the same problem
Mgsgreystang is offline   Reply With Quote
Old 09-04-2012, 09:50 AM   #14
Lorraine's driver
ab_mach1's Avatar
+1 Fill it slowly and stop when the compressor engages. Then you can read the pressures and add slowly, allowing the system pressures to steady. That will help keep you from overfilling the system. If you have a chiltons or Haynes, it will tell you what the proper pressures should be. After, you will need to hunt down your leak.
Old 09-04-2012, 11:57 AM   #15
01bullitt's Avatar
should i go to shop have them do the leak presure test they do
Old 09-04-2012, 12:31 PM   #16
Lorraine's driver
ab_mach1's Avatar
If you don't have a set of gauges and feel uncomfortable with tinkering with the AC system, you might consider it. You could ask them to just determine if it's a leak or a dead compressor, and nothing else. Maybe that would allow you to gather some funds to finish the job at a later time.
03:42 AM
