Lowering - Mustang Evolution
Old 09-03-2012, 06:12 PM   #1
RUNNWLD's Avatar
Region: Utah
Lowering
My spring and camber bolts should be here by Thursday and I was just wondering when I get it all installed should I get it aligned or should I let it sit for 2 weeks and let it settle then get it aligned?
RUNNWLD is offline   Reply With Quote
Old 09-03-2012, 06:20 PM   #2
ColeJohnson's Avatar
Re: Lowering
If you do it right you shouldn't need a re-alignment. And if you do then just take it to get it aligned right after install. Settling shouldn't cause any issues.
2016 Comp Orange GT (current)
Old 09-03-2012, 06:46 PM   #3
RUNNWLD's Avatar
Region: Utah
Okay thank you soo much man I hope the super sports with no isos and 1 in the back stance looks good!!?
Old 09-03-2012, 07:39 PM   #4
Re: Lowering
Well just look at my ride. I run H&R SS springs and X2Balljoints without spacers... I'm about as low as you'll be.
Old 09-03-2012, 09:30 PM   #5
RUNNWLD's Avatar
Region: Utah
When you mean without spacers do you mean like no isolators all around? If so what did you use instead of isos?
Old 09-03-2012, 09:49 PM   #6
I have isos in but no spacers on the ball joints. Your car would be about .2-.3" higher in the front if you don't use isos. And yours will be about .2-.3" lower in the rear than mine.
Old 09-03-2012, 10:01 PM   #7
RUNNWLD's Avatar
Region: Utah
Alright good to know thanks a lot!!
11:44 AM
