Help me fix an Anti-freeze leak! - Mustang Evolution
Old 09-03-2012, 11:35 PM   #1
TopgearGT's Avatar
I have an anti freeze leak that's kinda big and so far no one has been able to help! so i figured id be able to come to you guys! its leaking around this rubber seal under the thermostat. there is an arrow pointing to the specific spot where the leak is worst! what should i do? whats the name of that black rubber piece where the leak is? any info is good info!
http://www.mustangevolution.com/forum/users/25023-albums2837-17413.jpg
CSVT and 02 GT!
TopgearGT is offline   Reply With Quote
Old 09-03-2012, 11:39 PM   #2
1slosix's Avatar
Re: Help me fix an Anti-freeze leak!
it's the thermostat seal...go ahead and get a new one from any autoparts and swap it out
Old 09-03-2012, 11:42 PM   #3
TopgearGT's Avatar
when i went to autozone all they could find was the red o ring that goes under he thermostat. is that what im looking for?
CSVT and 02 GT!
Old 09-03-2012, 11:44 PM   #4
1slosix's Avatar
yea...i mean at Advance it's black, but color isn't really an issue...while you're at it grab a water outlet gasket for another $2 just to be safe
Old 09-03-2012, 11:54 PM   #5
TopgearGT's Avatar
ok thanks! will i have to remove the alternator bracket so i can remove the aluminum cross pipe that bridges over to the other side of the cooling system? or will i just remove the top part of the thermostat?
CSVT and 02 GT!
Old 09-03-2012, 11:56 PM   #6
1slosix's Avatar
i'd try without removign the alternator first...worse comes to worse it's easy to pull off
Old 09-04-2012, 09:28 AM   #7
The bolts to take the crossover off are under the manifold so you have to take the hole manifold to fix it. The gasket between the crossover isnt sold so you might have to use some black rtv. I had a similar problem but on mine the plastic piece right under the thermostat broke on the inside
Mgsgreystang is offline   Reply With Quote
Old 09-04-2012, 11:12 AM   #8
TopgearGT's Avatar
So should I probably have a mechanic do the work? What's the difficulty level?
CSVT and 02 GT!
Old 09-04-2012, 11:31 AM   #9
Forum Car Trader
90GTNovi2000's Avatar
Do that yourself!!! Take your time. I'm pretty sure you can remove it without pulling the manifold, but refer to a chiltons for conformation
90GTNovi2000 is offline   Reply With Quote
Old 09-04-2012, 11:15 PM   #10
TopgearGT's Avatar
A chiltons? sorry if this is a dumb question but what is that?
CSVT and 02 GT!
Old 09-04-2012, 11:32 PM   #11
Lorraine's driver
ab_mach1's Avatar
Chilton and Hayne's, they are instruction manuals you can buy at auto parts stores for cars.
Instagram: @ab_mach1
Old 09-05-2012, 09:36 AM   #12
1slosix's Avatar
go to autozone.com and make a free account..there's a step by step on there in the repair section with pictures
Old 09-05-2012, 12:51 PM   #13
TopgearGT's Avatar
I created an account and went to the repair section! where do i go from there?
CSVT and 02 GT!
Old 09-05-2012, 03:41 PM   #14
1slosix's Avatar
under cooling...then click on the thermostat link..the top of the page is for v6's...at the bottom is the GT
Old 09-05-2012, 10:13 PM   #15
03torch's Avatar
I has the same thing happens to me but mine was in a different place
I'd suggest doing the removal and all yourself it really is quite simple just take your time and make sure the Seal isn't broken like mine was and I had to replace the whole intake manifold I'll put a picture of how mine broke tomorrow so you can just make sure it's not that
03torch is offline   Reply With Quote
Old 09-05-2012, 10:39 PM   #16
TopgearGT's Avatar
I figured it out!!! its actually nothing to do with any gaskets or seals or the thermostat! Its actually a common problem with these models! What it is is that black piece under the thermostat is part of the UIM and its cracked and so the UIM has to be replaced! the new one im getting from AM has the lower thermostat housing and cross over pipe built into it so its gonna be a fix that is definitely for the better! If this hasn't happened to you yet it probably will so i suggest replacing your stock UIM with one from AM!
CSVT and 02 GT!
Old 09-05-2012, 11:54 PM   #17
Silver Pony's Avatar
It happened twice on my old 98. First time in the same place second one cracked in the back where the heater hose clamped on. My 01 now has been replaced too. It was a recall from ford at one point.
Silver Pony is offline   Reply With Quote
Old 09-06-2012, 05:39 AM   #18
03torch's Avatar
Yup I figured that was it that was exactly how mine was leaking
A shop quoted me 1000$ dollars
Just do it yourself its pretty easy and if you need help getting anything apart just let me know I'll be glad to help
Old 09-06-2012, 12:41 PM   #19
TopgearGT's Avatar
Thanks man!
CSVT and 02 GT!
02:22 PM
