Troubles - Mustang Evolution
Old 09-04-2012, 09:04 PM   #1
SwatKatz901's Avatar
Troubles
Lately I've been having troubles with my car starting... I bought a new battery about two weeks ago and its still happening? My alternator isn't 8 months old. I don't know if it's my spark plugs or wires/connectors or something is going bad... Please if anybody have any ideas let me know lol
SwatKatz901 is offline   Reply With Quote
Old 09-04-2012, 09:19 PM   #2
charlie03fastGT's Avatar
Have u had ur starter checked out??
charlie03fastGT is offline   Reply With Quote
Old 09-04-2012, 11:51 PM   #3
Mile high JDF's Avatar
What sort of troubles?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-05-2012, 07:43 AM   #4
smknfstbullitt's Avatar
We need to know what its doing. Since you mentioned the battery and alternator, is it turning over? Cranking but not firing up? Does it always happen? Etc
smknfstbullitt is offline   Reply With Quote
Old 09-05-2012, 05:01 PM   #5
Sometimes When I go to turn it on... It won't start and it doesn't even make the clicking sound
Old 09-05-2012, 06:33 PM   #6
Have you looked at your grounds? The same thing happened to me and after replacing the battery and starter I learned that I had a corroded ground and maybe 3 copper strands connected
Old 09-05-2012, 08:54 PM   #7
I don't even know what to look for
Old 09-05-2012, 09:29 PM   #8
Look at the ground and see if there's a lot of battery acid on it.
Old 09-06-2012, 05:57 PM   #9
Alright I'll check it out today
Old 09-06-2012, 06:16 PM   #10
Re: Troubles
You may have a parasitic draw,,when you get it to start and you drive it ,,does it start back up ok,,If it starts ok,,and then you let it sit overnight,,and it doesnt start in the morning ,,you may have something draining the battery overnight
mymustang is offline   Reply With Quote
Old 09-06-2012, 06:22 PM   #11
It happens like every 3 days
Old 09-06-2012, 08:24 PM   #12
Re: Troubles
Alright when it happens ,,and it wont do anything,,do u jump it off and it will start??
Old 09-06-2012, 08:50 PM   #13
Yea it's been starting right up
Old 09-06-2012, 11:57 PM   #14
gqsmash's Avatar
Does jumping it always make it start or sometimes the same result of nothing?
gqsmash is offline   Reply With Quote
Old 09-07-2012, 05:30 AM   #15
It's usually fine.... It takes a while longer when I use a Honda to jump it, I don't know for what reason...
Old 09-07-2012, 07:20 AM   #16
Re: Troubles
Do you know how to do a draw test with a meter?? Do you have a meter or a test light??,,If so i can explain how to do it or you can look it up,,on the internet,, and down load it so you can copy it and take it with you,,But before you do that look closely that there is not any lights of any kind that are staying on,,trunk light,,glove box,,etc..Make sure you dont have anything plugged in the cigar lighter,,or power point,,,The draw test (parasitic draw)is not hard to do,,you prob have to have someone with you to do it though
Old 09-07-2012, 05:56 PM   #17
jdavis96gt's Avatar
Region: West Virgina
Re: Troubles
Had this prob on previous ride and it was a short. Every few days it wouldn't start. Start right up with a jump. Hope u figure it out.
Old 09-07-2012, 07:54 PM   #18
It's a fluke meter lol
Old 09-08-2012, 04:21 AM   #19
Re: Troubles
Alright,,make sure everything is turn off,,disconnect the neg battery cable,,turn the meter to miliamps,or amps,make sure you move the leads to amps on your meter,,put one lead on the neg battery post,,and the other lead on the neg battery cable,,it may spark a little and the numbers will go up..wait for about 5 mins,,the numbers should go down to less than 1/2 an amp,,something like .250 give or take a little,,if it shows anything on the left side like 1.25 or somthing higher than you have a draw,,if it shows 0,,than your fuse is blown in your meter
Old 09-10-2012, 06:30 PM   #20
I was told by an electricians mate that works in the USCG with me to just un-plug my fuse from out of my amp for a few days to see if I have the problem, so far I haven't had any issues with starting it so I'm going to purchase a kill switch and run it to my speakers to kill them... I checked my ground wire today at work and there turns out to be oil on my ground. But I'm not sure how to clean it up, can I use a pressure washer with screwing something up? Lol
Old 09-11-2012, 04:37 AM   #21
Re: Troubles
Cool that must of been what was causing the draw,,If you would have put the meter on the ground cable and the batt ground and then pull the fuse,,i bet you would have seen the drop..Brake cleaner cleans well,,
Old 09-11-2012, 01:52 PM   #22
Alright cool
10:12 PM
