Engine rebuild - Mustang Evolution
Old 09-05-2012, 08:11 PM   #1
Sonicblue11's Avatar
Engine rebuild
I'm currently rebuilding my motor and I'm boring the block .020 over and getting a forged crank and diamond dome pistons with h beam rods, also with trick flow twisted wedge heads! What other little things to I need when I start building it!? I need all the parts I need because I'm not too familiar with some stuff yett
Sonicblue11 is offline   Reply With Quote
Old 09-05-2012, 10:09 PM   #2
Re: Engine rebuild
Ya might want to consider fuel upgrades and MAF sensor upgrade
southernstang00 is offline   Reply With Quote
Old 09-06-2012, 04:17 AM   #3
Yeah I know all that, I mean like inside the motor wise, anything I'm missing?
Old 09-06-2012, 04:37 AM   #4
taylor98gt's Avatar
Re: Engine rebuild
get good, crank and rod bearings, all new grade 8 bolts/headstuds (arp is the best), piston rings, and gaskets of course.
taylor98gt is offline   Reply With Quote
Old 09-06-2012, 04:40 AM   #5
How much would all of that stuff run me?
Old 09-06-2012, 04:41 AM   #6
taylor98gt's Avatar
I'm not really sure, just check prices, I know arp stuff ain't cheap, but well worth the price IMO because you won't have to worry about them failing on you
Old 09-06-2012, 04:55 AM   #7
Yeah I know it's not cheap haha but I'm already in the process of doing it so
---------- Post added at 04:55 AM ---------- Previous post was at 04:44 AM ----------
Yeah I knew that haha I'm already in the process so I just need the parts now
Old 09-06-2012, 05:52 AM   #8
Mzilla's Avatar
To give you an idea here is a lIst I things I have completed with my build. Hope this helps
Mzilla is offline   Reply With Quote
Old 09-06-2012, 06:48 AM   #9
Nice dude do you have the motor in yett?
Old 09-06-2012, 06:53 AM   #10
Mzilla's Avatar
The motor has been out for 6 weeks and should be ready for me to pick up next week. Man I cant wait.
Old 09-06-2012, 06:57 AM   #11
jjsg09's Avatar
Don't ever go cheap on rebuilding a motor. Every bolt and bearing makes the difference. My suggestion to you would be a good oil pump and oil pan to lube that beast well. Also a windage tray might help too. What cams are you going with because domed pistons might get ptv clearence issues.
Old 09-06-2012, 07:57 AM   #12
I'm going with stage 2 cams
---------- Post added at 07:57 AM ---------- Previous post was at 07:49 AM ----------
10:39 PM
