Trickflow or??? - Mustang Evolution
Old 09-08-2012, 04:12 PM   #1
Bret21's Avatar
Trickflow or???
I'm looking at buying a good set of heads and cams. I've heard nothing but good about trickflow but wanted some other opinions.
Bret21 is offline   Reply With Quote
Old 09-08-2012, 04:27 PM   #2
jdavis96gt's Avatar
Region: West Virgina
Re: Trickflow or???
If I had the $ to spare, trickflow for sure. I haven't read up on it to much but I don't think nothing would compare to port & polish trickflow heads. I don't see u being disappointed.
Old 09-08-2012, 05:16 PM   #3
Bret21's Avatar
Yea that's what I was kinda thinking. What about patriot heads? Heard anything about them?
Old 09-08-2012, 05:23 PM   #4
jdavis96gt's Avatar
Re: Trickflow or???
No. Ill prob go ported pi heads. You give it sometime and other people will chime in and tell u from experience. But trickflow heads and a set of cams, it'd be a new machine. SC on that and then you have a beast.
Old 09-08-2012, 05:32 PM   #5
Mile high JDF's Avatar
I've heard that Patriot's have valve seals go bad a lot. But I haven't researched it much.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-08-2012, 06:18 PM   #6
Rm360's Avatar
I've heard the same ,I also heard of bent valves and broken valve springs, I would get my heads ported before I bought patriot, but if I had the $$$ I would definitely have a set of ported trick flow heads!!
Old 09-08-2012, 06:52 PM   #7
Filibuster
Or AFR. Those would be in the same price range maybe a bit more but offer up just as much as trickflow.
XXSTEVEO66 is offline   Reply With Quote
Old 09-08-2012, 06:53 PM   #8
I don't think AFR makes 2V heads or else I would buy some
Old 09-08-2012, 07:00 PM   #9
Filibuster
Ahh your probably correct I forgot about the whole modular thingy..whoopsie daisy!!..
I would definitely go trickflow then
Old 09-08-2012, 07:12 PM   #10
Yeahh I wish AFR would make heads for mod motors. They make some damn good heads.
Old 09-09-2012, 07:58 AM   #11
Bret21's Avatar
What about MHS ported heads? The price is fairly reasonable and it seems like I have heard good things about them. Should I go with comp 270's or some cams from MHS?
Old 09-19-2012, 07:26 AM   #12
Re: Trickflow or???
Stock bottom end 4.6L? How much power are you looking to make? I will be more than happy to help you out if you can give me details on what you are looking to achieve with your build.
Gregg
Trick Flow Tech
Gregg@TFS is offline   Reply With Quote
Old 09-19-2012, 10:28 AM   #13
sam minnick's Avatar
What is mhs
sam minnick is offline   Reply With Quote
Old 09-19-2012, 10:52 AM   #14
Originally Posted by sam minnick
What is mhs
Modular Head Shop
Old 09-19-2012, 11:17 AM   #15
Ahhhh yes i see thank you lol
Old 09-19-2012, 02:34 PM   #16
Bret21's Avatar
Well I have a forged bottom end. I just went ahead and sent my heads to livernois and they are doing a stage 2 port. I also have custom grind blower cams on the way. I may end up going with trick flow on down the road but for now I just went with stage 2 livernois. Would I see a huge power gain with trick flow rather than the ported heads?
Old 09-20-2012, 06:41 AM   #17
Re: Trickflow or???
Typical power gain on a head and cam build is around 130 hp + at the flywheel, but there are more benefits to our heads besides the gains in power. With our heads you get the replacable cam caps, 3/4" think decks and spark plug threads, revamped oiling system to get more oil to the caps and better piston to valve clearance due to the intake valve being moved to the other side of the cam. Thanks for keeping us in mind for future upgrades.
Gregg
Old 09-20-2012, 07:46 AM   #18
jdavis96gt's Avatar
Re: Trickflow or???
Gregg
What a nice upgrade. If ur reading ths Santa, that's what I want for x-mas.
02:06 AM
