Speedo issue - Mustang Evolution
Old 09-08-2012, 08:59 PM   #1
R6man's Avatar
Speedo issue
Bought the car recently and the speedo is off by ten mph. u think the gears have been changed. Anyway to see whata in it. I have sct tuner which will reset the speedo just need to know whats in it. Help
R6man is offline   Reply With Quote
Old 09-08-2012, 09:02 PM   #2
nhcowboy's Avatar
Gears or tire diameter is different than stock.
You can enter the tire revolutions per mile in the tuner. Go to the manufactures site and find out based on the size of the tire.
Small speedo differences are likely tire size (4-5 mph at around 50 mph). Anything more, likely gears.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 09-08-2012, 09:03 PM   #3
Mile high JDF's Avatar
Lift up the rear end of the car, make a mark on the driveshaft, rotate the tire one full rotation and count how many times the driveshaft rotates. 3.55 rotations means you would have 3.55 gears etc. Stock should be 3.27s
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-08-2012, 09:52 PM   #4
deadsp0t's Avatar
I think legally speedos can be off up to 10% from the factory. Speedos are off by % not MPH.
It's off by 10 mph at what speed? And what are you using to measure against? GPS indicated speed or a radar gun will be best to measure as other vehicles will be off also.
Also parts like speedo cables and gears can become worn depending on age and mileage. These parts and new tires that are the correct size could be factors.
That's unimpressive
Old 09-09-2012, 08:31 AM   #5
R6man's Avatar
Its off by ten at all speeds. Using one of those cop thing like a radar that shows ur speeds
Old 09-09-2012, 09:35 AM   #6
deadsp0t's Avatar
With that being the case before I started changing things around I would get a second opinion or confirmation from another source to confirm that it's actually off.
That's unimpressive
Old 09-09-2012, 09:52 AM   #7
JetLife 01GT's Avatar
Do you have any radar speed signs? Those things seem to be pretty damn accurate. They usually have them around school zones or in residential neighborhoods that they don't want people to speed on. I'd drive by that signs at different speeds and write down what ur dash says and what the sign says. The signs look like this.
I've seen signs that are 55 mph ones. This was the only good Internet pic I could find lol
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 09-09-2012, 09:58 AM   #8
deadsp0t's Avatar
idea
That's unimpressive
Old 09-09-2012, 11:03 AM   #9
nhcowboy's Avatar
If you have a smart phone, there are a ton of GPS based apps... Many tell you real time speed.
12.538 ET @112.33
Old 09-09-2012, 11:16 AM   #10
R6man's Avatar
I just need to figure out what gears I guess
07:22 AM
