fan belt for 00 GT - Mustang Evolution
Old 09-10-2012, 08:13 PM   #1
shadow commando's Avatar
fan belt for 00 GT
I'm looking to replace the fan belt on my car, is there a name for the belt that by passes the a/c compressor?
shadow commando is offline   Reply With Quote
Old 09-10-2012, 09:21 PM   #2
1996mustang's Avatar
Serpentine belt or drive belt
Old 09-11-2012, 01:20 AM   #3
1slosix's Avatar
Re: fan belt for 00 GT
Is there a reason you want to bypass your compressor? If you are not planning to use it and are going to remove it then ask for a bypass pulley ....your stock belt will still work this way. If just wanting to run no a/c temporary then use a string and run it on your pullies like you would a belt. Measure that string out after you ran it perfectly ....now tell the auto parts you need a belt that length in whatever rib youre running
carving corners like a boss
Old 09-11-2012, 05:14 AM   #4
My ac compressor locked up and can't afford to replace it right now so I just want to by pass it temporarily
02:30 AM
