Strut bar - Mustang Evolution
Old 09-11-2012, 01:06 PM   #1
sally2002's Avatar
Strut bar
K so I got this off Craigslist super cheap but doesn't have any mounting hardware to mount it to my 02 gt aka Sally. Can anybody help me out here. No brand name stamped or anything
sally2002 is offline   Reply With Quote
Old 09-11-2012, 04:15 PM   #2
LAS97GT's Avatar
That's a 94-98 GT convertible premium/Cobra strut brace. I have one stock on my vert.
---------- Post added at 05:15 PM ---------- Previous post was at 05:11 PM ----------
Strut tower has to be tapped to accept 10mm bolts. Have the nuts welded from inside the tower if you can. Mine are factory installed. Better yet, get an after market mod, could be cheaper.
---Las97GT
Old 09-11-2012, 05:14 PM   #3
sally2002's Avatar
So it won't work on mine then beings it is an 02
Old 09-11-2012, 11:19 PM   #4
02PONY's Avatar
No it won't work and I think I know who u got it from and I told him it wouldnt fit his that's why he sold it
02PONY is offline   Reply With Quote
Old 09-11-2012, 11:31 PM   #5
1slosix's Avatar
Re: Strut bar
it'll work just fine if you tap your own holes on the strut tower...i put one on my '04 that came off of a '94 vert
carving corners like a boss
Old 09-11-2012, 11:32 PM   #6
infamous281's Avatar
Make it work duh ! Lol
Old 09-12-2012, 09:20 AM   #7
sally2002's Avatar
He told me it would fit mine. Som gun.
---------- Post added at 02:19 PM ---------- Previous post was at 02:19 PM ----------
Oh I'm going to try
---------- Post added at 02:20 PM ---------- Previous post was at 02:19 PM ----------
What size bolts did you use
Old 09-12-2012, 09:20 AM   #8
02PONY's Avatar
U can drill holes and make it work but I'm not into hacking
Old 09-12-2012, 09:22 AM   #9
sally2002's Avatar
Lol me either I think I'll just see if I can trade
Old 09-12-2012, 09:25 AM   #10
Lorraine's driver
ab_mach1's Avatar
I bet you can make it work.
Instagram: @ab_mach1
Old 09-12-2012, 11:25 AM   #11
sally2002's Avatar
Ya I no I can I'm just a little hesitant lol
Old 09-12-2012, 06:05 PM   #12
1slosix's Avatar
Re: Strut bar
it takes 20 minutes to drill the holes and put it on...if you don't want it send it my way lol and i'll slap it on my sixxer
Old 09-12-2012, 06:50 PM   #13
sally2002's Avatar
How do you drill for the back tho lol
Old 09-12-2012, 07:01 PM   #14
1slosix's Avatar
Re: Strut bar
i just made a spacer to put between the back of the bar and that flange on the fire wall sitting about an inch below it..drilled a couple holes in that flange and bolted it down
Old 09-12-2012, 10:09 PM   #15
Siendly22's Avatar
Pretty clean bro
Siendly22 is offline   Reply With Quote
Old 09-18-2012, 09:47 AM   #16
LAS97GT's Avatar
Oh I'm going to try
Mine used 10mm that are about 1" long at the fire wall, and 1.5" long at the struts. Mind you you should try to get the receiving mounting nuts welded inside the tower, which means removing front struts and springs.
---------- Post added at 10:47 AM ---------- Previous post was at 10:46 AM ----------
Also, check throttle body clearance before you begin any work!!
---Las97GT
Old 09-18-2012, 04:38 PM   #17
sally2002's Avatar
I just changed my plenum and added a spacer and now it won't fit so I'm going to sell it now. I'll probably try and fab my own strut bar now
Old 09-18-2012, 08:40 PM   #18
1slosix's Avatar
Re: Strut bar
not too hard...or go to any trailer company and give them the specs of what you want. they can bend one up in a jiffy for cheap
Old 09-18-2012, 09:26 PM   #19
sally2002's Avatar
That's a good idea. I'll look into that thanks.
06:27 AM
