97 gt advice - Mustang Evolution
Old 09-11-2012, 02:11 PM   #1
97 gt advice
I have a 97 gt with an 01 motor and fiv speed tans with 3.55 gears. I'm lookin for some more power. Any advice on which direction I should go with cams before I got fi?
blazinjam3 is offline   Reply With Quote
Old 09-11-2012, 03:08 PM   #2
LAS97GT's Avatar
Get to know your compression ratio (9:4:1-10:1 I think). FI needs lower comp ratios, or, piston change may be needed. Am no expert though.
---Las97GT
Old 09-11-2012, 05:32 PM   #3
taylor98gt's Avatar
If he's full swap then his compression should be 9 to 1 or whatever the new edges are unless he just did the pi swap
taylor98gt is offline   Reply With Quote
Old 09-11-2012, 05:48 PM   #4
Mustang936's Avatar
Exhaust is great way to power and sound! Headers mud pipe and cat back will set you up good, if you don't want to do lontubes then just an off road mid pipe(if you can have one) and cat back will free up some power. A cold air intake, under drive pulleys, and a tune will really give the stang some more power
Mustang936 is offline   Reply With Quote
Old 09-11-2012, 05:49 PM   #5
oldkid's Avatar
Re: 97 gt advice
Do you have a budget? Or disposable income? Is this your main transportation?
Edit Value
"Life has a way of ****ing things up when you get happy"
oldkid is offline   Reply With Quote
Old 09-11-2012, 06:31 PM   #6
LAS97GT's Avatar
Should be 3:27 gears. Never heard of 3 :25.
---------- Post added at 08:30 PM ---------- Previous post was at 08:29 PM ----------
9:4:1
---------- Post added at 08:31 PM ---------- Previous post was at 08:30 PM ----------
Good question. It sure influences planning. +1
---Las97GT
Old 09-11-2012, 07:31 PM   #7
LAS97GT's Avatar
Looks like he did the whole mortor.
---------- Post added at 09:27 PM ---------- Previous post was at 09:26 PM ----------
+1, models before 05 gain through boltons
---------- Post added at 09:31 PM ---------- Previous post was at 09:27 PM ----------
Real deal. Call ford racing and get their advice on can upgrades, then find a speed shop and ask the same questions. Issue is valve to piston clearance with any pistons over stock, also timing change. You can't change timing which means dyno time. Custom tuning is )250-400 depending on what the tech had to do.
---Las97GT
Old 09-12-2012, 05:29 AM   #8
Re: 97 gt advice
Its a complete motor and trans swap and they are 3:55 gears. I was planning on stage two cams and having the heads worked and I also just found out the cars ecu has already been reflashed with a tune. Thanks for the advice any recomendations on certain brands to buy and ones to stay away from? I'm a college student so this is my dailey driver but also my project car.
09:25 PM
