Egr removal? - Mustang Evolution
Old 09-11-2012, 08:00 PM   #1
Egr removal?
Need advice on removing the egr. Any issues that would come from removing it other than poor mpgs
Cmrtopher is offline   Reply With Quote
Old 09-11-2012, 09:26 PM   #2
1slosix's Avatar
Re: Egr removal?
you won't even have poor mpg from it...you'll throw a code so if you can't kill the code with a tune you'll not be able to pass emissions. just get an EGR block plate and take it off..and plug of the vaccum hose at the other end
carving corners like a boss
Old 09-11-2012, 09:27 PM   #3
Re: Egr removal?
They took mine off when I had it tuned, the only issues you might see is the check engine like come on for a few codes. The only way you can fix that is bring it near a place that tunes them and ask them to cut it off in the computer. Far as running issues I never say a problem.
---------- Post added at 10:27 PM ---------- Previous post was at 10:26 PM ----------
haha I think we were typing at the same time
southernstang00 is offline   Reply With Quote
Old 09-11-2012, 09:51 PM   #4
1slosix's Avatar
Re: Egr removal?
lol fast typers unit
Old 09-11-2012, 10:01 PM   #5
Haha ok guys. I am suspecting a bad egr valve on an issue I'm having where the car skips when it's heated up, but I don't want to replace the valve in case it's not the issue. I happen to be replacing the clutch right now so I'm under the car to do it right. (cap off the port on the manifold)
Thanks rapid typers!
Old 09-11-2012, 10:14 PM   #6
Re: Egr removal?
I guess so lol
---------- Post added at 11:14 PM ---------- Previous post was at 11:11 PM ----------
well the only thing I can tell ya on that is go ahead and cap it off....because if you disconnect it and see how the car acts. If you have a tuner you can run it by a place and have them turn it off in the tune and load it on the tuner and retune the car.
12:21 PM
