03 gt smoking - Mustang Evolution
Old 09-12-2012, 10:47 AM   #1
trejo_03's Avatar
03 gt smoking
Im pretty shure its oil not shure if its my pistion rings. I did a head job on it at the begining if the summer I just finished. I drove the car then after a month or two it was smoking white after temps got normal
I rebuilt the heads
Replaced Valve 3 and 4
Bought the whole gasket kit to rebuild top end
Change oil (royal purple 5/20)and flushed coolant
What could be the possible problems
trejo_03 is offline   Reply With Quote
Old 09-12-2012, 01:26 PM   #2
infamous281's Avatar
I rebuilt the heads
Thats Piston Rings for sure.. Check compression
Old 09-12-2012, 02:15 PM   #3
Mile high JDF's Avatar
Did you replace your head gaskets?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-12-2012, 03:21 PM   #4
trejo_03's Avatar
Yes the whole reason I did the head job
Old 09-12-2012, 03:33 PM   #5
Piston Rings ! .. Check Compression..
Cough Cough
Old 09-12-2012, 03:39 PM   #6
Did you reuse your head bolts? If I remember right they are torque to yield. Check your oil level and coolant level.
Old 09-12-2012, 03:41 PM   #7
trejo_03's Avatar
No I replaced head bolts and oil level keeps getting lower
Old 09-12-2012, 04:29 PM   #8
Then it's most likely your piston rings.
Old 09-12-2012, 09:41 PM   #9
03whitey's Avatar
Thought white smoke was gas not oil when my car us richend up with the tuner it has white smoke but not alot and eventlly clears up
03whitey is offline   Reply With Quote
Old 09-13-2012, 02:18 AM   #10
trejo_03's Avatar
Well I don't have a tuner just an intake and exhaust. I was pretty shure that's what it was I just breally started saving the money to get the motor rebuilt but what could I do to get it to maybe slow down the burning of the oil can I change to something thicker?
Old 09-13-2012, 11:39 AM   #11
sam minnick's Avatar
How do you use this
sam minnick is offline   Reply With Quote
Old 09-13-2012, 12:12 PM   #12
It's been a while since I looked, but I think Auto Zone or any parts store carries an oil additive that's supposed to help slow down how much oil you burn,
02:49 AM
