Cobra calipers how to? - Mustang Evolution
Old 09-12-2012, 06:50 PM   #1
M97cobra's Avatar
I've only had my cobra for a short while had the tires off yesterday not seeing how the cobra calipers come off don't see any bolts or screw just wut looks like some kind of push in retainers on the outside of the calipers is that how there held in? Or?
M97cobra is offline   Reply With Quote
Old 09-12-2012, 07:22 PM   #2
Two bolts on the back side. One at top, one at bottom.
For brake pads just undo the two smaller bolts on the upper end of the caliper and remove the piston assembly leaving the pads in place.
Old 09-12-2012, 07:41 PM   #3
M97cobra's Avatar
I only saw two goid bolts for the caliper cradle which I think the caliper bolts did c any more,I had a f-150 before the cobra and had the same system but the caliper bolts are no ware to be seen
Old 09-13-2012, 05:27 PM   #4
Re: Cobra calipers how to?
To access the pads, remove the pin going through the bottom of the caliper. The caliper swings up over the bracket with the pads secured to it by circular spring clips.
8111870 is offline   Reply With Quote
Old 09-13-2012, 05:54 PM   #5
M97cobra's Avatar
Ok thank you
05:14 AM
