mustang gt 2000 - Mustang Evolution
Old 09-16-2012, 03:19 PM   #1
arezo's Avatar
mustang gt 2000
Ok i have a 2000 gt .. Im confused when My car turns on no lights are on.. Then when i click the over drive button it says od off. .. So does that mean od automatically comes on when its turnd on My bf thinks when i.click the button n it says od off it means its on ..? It drives like its on od when it says its off !? Help!
arezo is offline   Reply With Quote
Old 09-16-2012, 03:26 PM   #2
nhcowboy's Avatar
When it is showing, it is off meaning overdrive is not engaged.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 09-16-2012, 05:42 PM   #3
Re: mustang gt 2000
When your turn your car on the green o/d light is not lit. This means overdrive is engaged, so you have that 4th overdrive gear engaging for lower rpms and better fuel efficiency. If always defaults to being on.
If you press the button and the light is lit up on your dash, then the o/d is turned off, or not engaged. Your transmission will basically act ike a 3spd and won't engage that 4th overdrive gear.
03:09 PM
