Motor Oil and Filter - Mustang Evolution
Old 09-16-2012, 04:33 PM   #1
Trickster929's Avatar
Region: Hawaii
Hi! I just bought a 2000 Mustang GT. What's the best oil and filter to use? I'm new to Fords and Mustang so I need advise. Thanks!
Trickster929 is offline   Reply With Quote
Old 09-16-2012, 04:45 PM   #2
LAS97GT's Avatar
Fords use 5/20. Go Syntech. Helps with the close tolerances and engine temps.k
---Las97GT
Old 09-16-2012, 05:31 PM   #3
sally2002's Avatar
I use motor craft oil and k&n oil filter
sally2002 is offline   Reply With Quote
Old 09-16-2012, 06:25 PM   #4
1996mustang's Avatar
Mobil 1
Old 09-16-2012, 06:33 PM   #5
BigpapaDean's Avatar
Castrol syntech... Been using it on my 99 wrangler for 8 yrs and now on my 67 fastback.
BigpapaDean is offline   Reply With Quote
Old 09-16-2012, 07:33 PM   #6
Re: Motor Oil and Filter
mobile 1 synthetic motorcraft oil filter
mymustang is offline   Reply With Quote
Old 09-16-2012, 07:45 PM   #7
Mzilla's Avatar
I use Royal Purple 5w-30. I also know two professional engine builders that only use Valvoline VR1.
Mzilla is offline   Reply With Quote
Old 09-16-2012, 07:46 PM   #8
Oil you will hear a different opinion from everyone.
Motorcraft 820s is the only oil filter you should use period.
I use royal purple in the cobra, mobil 1 in the gt.
Old 09-17-2012, 11:01 AM   #9
Venomouz831's Avatar
Knn oil filter and royal purple oil
)02 Gt, Founder of WE2G
Old 09-17-2012, 11:08 AM   #10
Lorraine's driver
ab_mach1's Avatar
I have been using the K&N oil filter with RP 5W-20 for the past few times, but decided to go with the Motorcraft 820S oil filter this time. I don't think the K&N is bad at all, I've just heard a lot of good things about the stock filter. Plus, it'll save me a little cash.
Instagram: @ab_mach1
Old 09-17-2012, 10:37 PM   #11
Region: Hawaii
Thanks everyone! I've decided on Mobil 1 and Motorcraft filter.
Old 09-17-2012, 10:58 PM   #12
S197STANG's Avatar
+1 I use the exact same
S197STANG is offline   Reply With Quote
Old 09-18-2012, 06:44 AM   #13
32vNomad's Avatar
Motorcraft synthetic 5w20 with 820S or ford racing's 820s.
32vNomad is offline   Reply With Quote
Old 09-18-2012, 06:47 AM   #14
jjsg09's Avatar
I've always used factory oil Motorcraft.
04:17 PM
