Stang in the stable - Mustang Evolution
Old 09-16-2012, 07:39 PM   #1
Matticus's Avatar
Stang in the stable
Took my stang to the shop to have my transmission rebuilt today. Probably gonna be gone for about a week :/ So I just have to manage off of seeing all of your mustangs on here for a bit.
Is there a break-in period after a rebuild like there is with a new clutch?
Matticus is offline   Reply With Quote
Old 09-16-2012, 09:19 PM   #2
1996mustang's Avatar
Dont quote me on it but i believe 500 miles is adequate enough but its been a qhile for me with manuals so someone who has experience qill chime in and u and i will learn if there is one
Old 09-16-2012, 09:53 PM   #3
maldog's Avatar
Region: Nevada
Re: Stang in the stable
May she come back stronger and faster
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 09-17-2012, 06:09 AM   #4
Matticus's Avatar
That sounds about right, it's gonna be torture not being able to run it hard once I have a functional 4th gear again haha
Old 09-17-2012, 10:37 AM   #5
Lorraine's driver
ab_mach1's Avatar
My new Exedy stage 1 clutch said 750 miles on the paperwork that came with it. I still have like 600 miles to go. It's probably around 500 - 750 miles. I guess this is pretty important to do because your grabbing strength can be reduced if the clutch is not work in properly. There is a Ceterforce video on YouTube that breifly talked about it. You could try "Centerforce Clutch Break-In" search. It does suck waiting, especially when your used to driving spirited.
Instagram: @ab_mach1
Old 09-17-2012, 02:27 PM   #6
mcvicar04's Avatar
When I got my exedy stage 2 it chattered for a little but after a month or do it went away and my mechanic said he drives it normal for a day or two then rides the clutch to heat it up then he beats the hell out of it and he said it never failed him, that's what I did and I have no problems
mcvicar04 is offline   Reply With Quote
Old 09-19-2012, 10:34 AM   #7
sam minnick's Avatar
I put in a new clutch drive it to work the next day and drove it to the track and ran 12.9 all night
sam minnick is offline   Reply With Quote
Old 09-19-2012, 10:39 AM   #8
Lorraine's driver
ab_mach1's Avatar
Sounds like a lot of the stage 2 and up clutches have more than enough grab that it doesn't really matter if they are broke in properly.
Old 09-19-2012, 11:16 AM   #9
I think if there installed properly in the first ten miles you know if there going to be ok... that's my opinion
Old 09-19-2012, 11:23 AM   #10
Lorraine's driver
ab_mach1's Avatar
You certainly could be right. The only reason I'm going through the suggested break-in is because I'm always overly careful with stuff and I believe Murphy's Law.
Old 09-19-2012, 11:43 AM   #11
mcvicar04's Avatar
The stage 2 is awesome because it has two different surfaces. If you set the clutch it will heat up and expand one of the surfaces I forget the name of it and it was grab like a mother I have never spun 3rd gear until I got this clutch
Old 09-19-2012, 12:17 PM   #12
Yea i been burnt not following directions lol
Old 09-19-2012, 08:45 PM   #13
Matticus's Avatar
Well the guy called me today and said based on him driving and looking at it, he doesn't think it's anything mechanical wrong, so he adjusted a few things and flushed the transmission fluid and filled it back up. Told me to come get it and If its still messing up after 2 weeks to bring it back
12:09 PM
