clutch - Mustang Evolution
Old 09-17-2012, 11:57 PM   #1
superboondee's Avatar
Region: Idaho
clutch
How do I adjust my clutch pedal. It releases near the top of the height the pedal goes or is that normal?
If you can't beat them, Get a supercharger.
superboondee is offline   Reply With Quote
Old 09-18-2012, 12:32 AM   #2
1slosix's Avatar
Re: clutch
that's how my GT was...you can lift up on the pedal and see if it clicks...if you hear it click its now adjusted..no click means it's already good to go. the only other way to adjust it is either with a firewall adjuster, or an adjustable quadrant...of course with any stickshift mustang i'd replace the plastic quad with a metal one just out of habit of wanting better quality parts on the car
carving corners like a boss
Old 09-18-2012, 12:05 PM   #3
Lorraine's driver
ab_mach1's Avatar
Re: clutch
Here's a how-to article that a member made for adjusting the stock cable setup...
How To Adjust OEM Mustang Clutch Cable - Mustang Evolution
Instagram: @ab_mach1
Old 09-18-2012, 09:25 PM   #4
Re: clutch
Also, mine was like that when I bought it a couple of months ago. Pulling up on the pedal made no difference, and I was PO'd. I had just learned to deal with it when last Sunday night, I was heading to church and the clutch just died. My dad and I pulled the transmission and found the friction material had shattered on one side and was almost non existent on the other. I replaced it, and now the pedal is perfect!
Cmrtopher is offline   Reply With Quote
01:58 AM
