Will this Tire Fit ? - Mustang Evolution
Old 09-19-2012, 06:37 AM   #1
infamous281's Avatar
I have 15x10 with I think 6.5 Backspace ..
I currently have 275/50/15 BFG Drags..
Was going to go 275/65/15 but saw
325/50/15 .. Curious if they would rub..
Old 09-19-2012, 10:15 AM   #2
Black99Snake's Avatar
I think a 315 is as wide as we can go on this body style but I'm sure someone else will chime in
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 09-19-2012, 11:23 PM   #3
t0t4lbl4ck0ut's Avatar
315 I believe. I have 315s on mine and you'll have to watch your suspension cause you can get some nasty rubbing.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 09-19-2012, 11:29 PM   #4
Sonicblue11's Avatar
Will 305s make you lose hp? More tire more rotation
Sonicblue11 is offline   Reply With Quote
Old 09-19-2012, 11:30 PM   #5
Venomouz831's Avatar
Never heard of a bigger tire making you loose hp, the wider the tire the more grip you have so you can put the power down
)02 Gt, Founder of WE2G
Old 09-19-2012, 11:33 PM   #6
Yeah that's what I thought as well haha my friend keeps telling me if I go with 305s i will lose hp haha so I figured I'd just put it out there
Old 09-19-2012, 11:36 PM   #7
Lol no he must be on something, I have 305's and didn't feel a power loss
Old 09-19-2012, 11:37 PM   #8
Technically the wider the tire the more weight and you would lose hp from rotational mass. But it would be such a tiny amount you wouldn't even notice. Much like a light weight flywheel but on a much smaller scale.
Old 09-20-2012, 12:19 AM   #9
irishn8's Avatar
Then u could go on a diet, loose 5lb and gain that rwhp back
Old 09-20-2012, 12:21 AM   #10
Yea or loose ure spare
Old 09-20-2012, 12:30 AM   #11
irishn8's Avatar
Ya replace that and the jack with liquid spare hehe
Old 09-20-2012, 12:44 AM   #12
Lol
Old 09-20-2012, 07:46 AM   #13
Las0mbra's Avatar
Actually, losing a pound of rotating mass is like losing 10x that in dead weight... So lets say you can save 2lbs a wheel, you're in a way saving about 80lbs all around.
Old 09-20-2012, 05:09 PM   #14
sam minnick's Avatar
I think i was told for every 3 pounds of rotating mass is equal to 27 pounds... dont quote me on the exact numbers but i def heard something like that
sam minnick is offline   Reply With Quote
Old 09-20-2012, 05:54 PM   #15
irishn8's Avatar
Anyway the added rotational mass is a necessary evil. Illustration: two identical mustangs, one has nitto555 drag radials 12" wide and the other has bicycle tires...
Old 09-22-2012, 12:30 AM   #16
Las0mbra's Avatar
I get that, but if you have a car with say 400rwhp, 10 in slicks should be just as good as 12in slicks if you're a good driver.
---------- Post added at 01:30 AM ---------- Previous post was at 01:29 AM ----------
3lbs/27lbs is 1/9, almost the same as the ratio I mentioned, so yes, you heard correctly. It's something in that range.
Old 09-22-2012, 06:23 AM   #17
Even if your tire and wheel is heavier if you got more rubber on the ground and thats better traction... so to me having better traction is worth spinning a little bit more weight..
Old 09-22-2012, 07:48 AM   #18
Las0mbra's Avatar
But there comes a point where you don't need more than a certain amount of rubber. Not everybody needs to be rolling on 325 drag radials.
Old 09-22-2012, 08:38 AM   #19
Yesterday i seen a badass 02 and ut had a huge set of tires on the back and it looked awesome
Old 09-22-2012, 09:51 AM   #20
Jinielle's Avatar
No power loss indeed. Go with 305 they look sick as hell! I have the Nitto NT555 extreme drag radials 305/35/18 on my car. i say you go for it:p
Jinielle is offline   Reply With Quote
Old 09-22-2012, 10:15 AM   #21
On the gt I agree 305 is good enough because with 240-300 hp thts enough. On a v6 275 is the most thread you would need 200hp n under. But really we all like it for how sick it looks in the rear having some meaty wife tires
Old 09-22-2012, 10:30 AM   #22
I have a couple pics to help distinguish the size. First it's my red v6 with 275's and them my blk gt with 305's
ID:	69575   Click image for larger version
ID:	69578   Click image for larger version
01:18 AM
