Alternator charging issue - Mustang Evolution
Old 09-19-2012, 10:47 AM   #1
1ijack's Avatar
Send a message via Yahoo to 1ijack
I have put a 05 alternator on a 99 gt and it worked get but now I have started going through 4 alternators and 3 batteries. The alternator is charging at 11.75 volts on the car, but on a bench tester it tested at 13.54 volts.
Need help with this Ford has no solution and asking for help or I am sunk. If you can help please respond need suggestions on this soon.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 09-19-2012, 11:14 AM   #2
Voltage258's Avatar
Region: Utah
Do you think it's possible to have a very serious power draw and that's what's dragging it down and killing your battery's?
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 09-19-2012, 01:54 PM   #3
1ijack's Avatar
Not running anything but stock. Checked all grounds and cable maybe a harness going to alternator but still confused
The Mustang Mafia
Old 09-19-2012, 01:57 PM   #4
irishn8's Avatar
+1
Sounds like there is a serious short going on there.
Inspect all wiring and conectors.
Old 09-19-2012, 02:03 PM   #5
1ijack's Avatar
If it is don't know where it could be. But at my wits end and thinking of selling and really don't want to. This is my first and paid for and done so much to it like my own child.
The Mustang Mafia
Old 09-19-2012, 02:22 PM   #6
Voltage258's Avatar
Region: Utah
Does your battery drain while the car is off?
Old 09-19-2012, 02:39 PM   #7
irishn8's Avatar
U won't have to sell. Sometimes these probelms seem daunting but ends up being something simple. So many times I got the car someone else gave up on ans sold cheap then I fixed it in minutes. Sometimes just takes a fresh set of eyes I guess. Take a step back and sleep on it if u have to. Ull get it
Old 09-20-2012, 12:24 AM   #8
1ijack's Avatar
No doesn't drain when car off. Only pulls when car is started.
---------- Post added at 02:24 AM ---------- Previous post was at 02:22 AM ----------
I am trying but fighting this for almost the last three weeks is just murder for me.
The Mustang Mafia
Old 09-20-2012, 12:36 AM   #9
irishn8's Avatar
What amp alt are u using? They make two different alts with two different amp ratings. I had similar problems until got the alt with the higher amp rating. Still seems like a short though.
---------- Post added at 11:36 PM ---------- Previous post was at 11:33 PM ----------
The voltage on ur battery should be 12 to 13s with the car off and 14s with the car running.
Old 09-21-2012, 08:14 PM   #10
1ijack's Avatar
Amp is 135 amp. Ordered new harness for alternator and hoping that fixes the issue but I don't know.
The Mustang Mafia
Old 09-21-2012, 10:51 PM   #11
Mfore33's Avatar
Check for short on starter?
Old 09-22-2012, 06:30 AM   #12
LAS97GT's Avatar
Go to your Hanes manual. While engine is off, connect test light between the negative terminal and ground. It it lights, you have a fault. You shouldn't have positive voltage on the negative side. Next, while keeping the test light connected, begin pulling fuses (under hood first) till the light goes out. If the light goes out to, say the alternator, but fuse is undamaged, get a multimeter with a buzzer if possible and begin checking the grounds. If you have a buzz with a hot and ground. Guess you know what that means. Also, get your alternator tested. Autozone, advance auto, pep boys, they all do it for free. One more thing. Try starting the engine without the radiator fan, it might be burned. It melts down (fire hazard) when it quits.
---------- Post added at 08:30 AM ---------- Previous post was at 08:29 AM ----------
Correction: get your starter tested.
---Las97GT
Old 09-23-2012, 07:33 PM   #13
1996mustang's Avatar
I have a simple question......does an 05 alty work on the 96? And how did u do it? Oh and maybe some silly input does the voltage at the battery match the voltage from the alty wire to ground? I read feom all data on 05-09 ha ing issues with altys due to pcm comm wire broke or stripped. Would look into your wiring diagram to see where a stripped wire would ground out or see where a loss of connection would be
Old 09-27-2012, 12:00 PM   #14
1ijack's Avatar
Charging issue is fixed and car charging at 14.36 volts. Found some bad wires in old harness replaced it. Runs great.
The Mustang Mafia
Old 09-27-2012, 07:05 PM   #15
Voltage258's Avatar
Region: Utah
Glad to hear
Old 09-28-2012, 12:33 AM   #16
1ijack's Avatar
Glad to hear
Thank you
The Mustang Mafia
10:08 AM
