What makes my theft light blink? - Mustang Evolution
Old 09-21-2012, 12:28 AM   #1
03whitey's Avatar
Just a curious question but what makes my theft light blink? When it does that my car just sits there and turns over and wont start? Tuner maybe? It only does it every now and then, at first i thought fuel pump but noticed it only did it when the theft light was blinking
03whitey is offline   Reply With Quote
Old 09-21-2012, 01:30 AM   #2
Black99Snake's Avatar
That's your pats. If you have a tuner on your car take the tune off and flash the stock tune to it. See if that helps I read somewhere that sometimes if it don't flash all the way or properly it can cause that. Good luck
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 09-21-2012, 03:50 AM   #3
wolfstang03's Avatar
Mine always flashes, but still runs and starts. I re-tuned it and still the same thing.
--WOLFSTANG 03--
wolfstang03 is offline   Reply With Quote
Old 09-21-2012, 12:16 PM   #4
Mustang936's Avatar
Re: What makes my theft light blink?
Mine is like that but runs just fine
Mustang936 is offline   Reply With Quote
Old 09-21-2012, 06:52 PM   #5
03whitey's Avatar
I returned my car to stock and re flashed the computer and its starting fine! Maybe itll be ok now, preciate it guys!
Old 09-21-2012, 09:08 PM   #6
Mine use to flash for a good bit when I tuned my car but eventually went away. If the car is starting and running ok then no worries. If you want try another key if you have one as a spare and see what it does.
southernstang00 is offline   Reply With Quote
Old 09-21-2012, 10:55 PM   #7
03whitey's Avatar
Well it started back again haha i spoke to soon! I lost the main key to the car and im haveing to use my spare could that be part of the problem?
---------- Post added at 11:55 PM ---------- Previous post was at 11:53 PM ----------
Whats going on my memphis buddy? Lol man did you read the thread i started about my torque converter over heating my transmission?? If not go read it and give me ur opinion if you dont care! Lol
Old 09-23-2012, 03:31 PM   #8
Thats possible its the spare key or maybe a valet key or something just guesses.
Dayum dude I didnt know that messed your tranny up, I cant find the thread post something it in to make it fresh.
Old 09-23-2012, 03:52 PM   #9
If the theft light flashes rapidly,,it means theres a problem with the pcm getting the password from the PATS module..Ive seen a key do that,,you can try a different key and see if that helps,,also theres a plastic round thing right around the key cylinder,,inside the cover,,they call it a anntena..(ford does),,ive seen that on alot of fords go bad..But if the tune makes it do it maybe theres a problem when its loading..I know they tell ya to use a battery charger while your loading it to keep the battery up,,i also read that not to have another vehicle key close to the switch ,,that it could interfere with the signal,,never had that happen personally,,but you never know
mymustang is offline   Reply With Quote
Old 09-25-2012, 10:55 AM   #10
tfalk's Avatar
Do you have a tilt wheel? If so, when you have the problem, is the wheel up or down? I had the same problem with my 99 but only when the wheel was up... turned out there is a wiring harness in the column that was shorting out only when the wheel was up....
99-122 Bright Atlantic Blue S281 S/C Convertible
11-025 Grabber Blue S302 Convertible
Saleen - Power in the hands of a fool!
tfalk is offline   Reply With Quote
Old 09-25-2012, 11:33 AM   #11
03whitey's Avatar
Yes i have a tilt wheel, i keep it down all the time unless my girlfriends drives then shes got everything on the driver side messed up lol
Old 09-26-2012, 10:36 AM   #12
fomoco4life's Avatar
I had this problem, changed key and fob....no help....turned out it was the car battery
05:18 PM
