Will the mach shaker hood and system... - Mustang Evolution
Old 09-22-2012, 07:03 PM   #1
Masafreah's Avatar
Will the 03-04 mach 1 shaker hood and system work on my 99 gt.. I can do minor mod but is there something I'm over looking, I'm planing on going tomorrow an getting a whole set up hood shaker and air box for $250 or an I wasting my time or money trying ?
Masafreah is offline   Reply With Quote
Old 09-22-2012, 07:22 PM   #2
I'm pretty sure it will bolt up
Cdbformula is offline   Reply With Quote
Old 09-22-2012, 07:25 PM   #3
Mezmer's Avatar
Re: Will the mach shaker hood and system...
The shaker is just bolted on. So if you have the entire setup it should work.
2004 Mustang Mach 1 - SY
Exhaust - Wanna be Flomasters...
JLT Ram Air Intake
SR Performance Short Throw Shifter
Mezmer is offline   Reply With Quote
Old 09-22-2012, 08:03 PM   #4
Masafreah's Avatar
Right on I seen the add for 250 so I fig I would snatch it up! Because the CDC kits cost 700+
Old 09-22-2012, 08:11 PM   #5
Lorraine's driver
ab_mach1's Avatar
See if you can do some measurements before you buy the setup. I can't find where, but I think I read once the height of the motors sit differently. I could be wrong. I just remember reading something somewhere. I am willing to take some measurements on my motor for reference if you'd like. Let me know.
Instagram: @ab_mach1
Old 09-22-2012, 08:13 PM   #6
2002VertGT's Avatar
To make it work you have to fab or buy a different bracket for the shaker to bolt to the motor....google it there is a guy that sells them...
4.10 Gear/RPM thread
Old 09-24-2012, 12:39 AM   #7
crozz's Avatar
Anybody know if there would be an issue mounting the shaker to a BBK throttle body, they are a fair bit thicker than stock.
crozz is offline   Reply With Quote
Old 09-24-2012, 12:48 AM   #8
DaBluedude's Avatar
You will need the brackets, upper and lower scoop pieces, The center rubber gasket/water gaurd, the hood and intake pipe. From there you may have to modify so the brackets will work. I understand there are some modifications needed. Either way for that price that's a Good deal. As long as the top of the shaker scoop is in good condition. If it's just discolored I recommend spraying it with a Couple layers of plasti dip. Looks great and way cheaper than re-powder coating it.
2003 Mach 1
Old 09-24-2012, 04:55 AM   #9
Venomouz831's Avatar
It should bolt up
)02 Gt, Founder of WE2G
Old 09-24-2012, 06:09 AM   #10
jjsg09's Avatar
Yea I think you need to do some custom fab work to get it to set just right. 2V motors set a little lower than the Mach 1 motor. There is a guy that did his on a GT and had to raise it about a half an inch. I think he went to a hardware store and found something that worked as spacers.
Old 09-24-2012, 08:43 AM   #11
DaBluedude's Avatar
You also need to modify it for where the mounts connect to the engine.
2003 Mach 1
Old 09-24-2012, 08:50 AM   #12
Lorraine's driver
ab_mach1's Avatar
^All this +1
Old 09-24-2012, 10:40 AM   #13
sam minnick's Avatar
What motor is in the mach 1
sam minnick is offline   Reply With Quote
Old 09-24-2012, 10:42 AM   #14
1lowGT's Avatar
4.6 dohc 32v
Old 09-24-2012, 12:06 PM   #15
Oh ok i see dam you ford i got screwed with the 2v lol
Old 09-25-2012, 07:42 AM   #16
2002VertGT's Avatar
You can do it...there is one bracket you have to change....as long as the system comes with all the necessary mounting pieces to begin with...if ur not gonna get it give me the guys info
» Members Mustangs
SHADOW
SHADOW
Stella
Lovin14
Add your Mustang
07:06 PM
