fluctuating rpm's - Mustang Evolution
Old 09-26-2012, 04:50 PM   #1
fluctuating rpm's
Hey guys,
I'm new but I'm on my second Mustang. I've got a '97 GT and was wondering if anyone could throw me some advice.
When I'm at a light or at idle in general my RPMs start to fluctuate a little and she jerks a little. The same type of "jerk" happens just below 2000 or sometimes if the throttle is in a certain position. In addition to that, there is also a strange noise at higher RPMs, but I'm not sure how to describe this noise. Any help would be greatly appreciated...
Oh, here she is by the way...
rmlf1995 is offline   Reply With Quote
Old 09-26-2012, 05:22 PM   #2
The fluctuation could be mass air sensor....but since it does it at other rpms under steady throttle, check out the throttle position sensor. Also, has it thrown a code, is there a check engine light on or any indicator on in the cluster? The higher rpm noise....without a description now way of knowing.
Grabber Blue "Betty" 2012 V6 Six Speed, 3.55, BBK cai/throttle body, longtubes, x-pipe, axle back w/oem tips, Lugo Performance Dynotune, Zex 100 dry. I need factory v6 foglight housings, and the stock 11/12 gt grill with the light housings.
WtFDiesel is offline   Reply With Quote
Old 09-26-2012, 08:49 PM   #3
The check engine light is on and I need to check the code. But it isn't on constantly, sometimes it will go off and then a day or two later it will cut back on...
Thanks for the advice by the way.
If it was the throttle sensor or the mass air sensor would it cause the car to run weak? The amount of power I get out of it is severely weak compared to what it should be and what it was not too long ago. Sorry for all of the questions, I'm not very knowledgeable about cars...
Old 09-26-2012, 09:33 PM   #4
Yes it/they will. Anything that affects the car's ecu will affact the power output.
Old 09-26-2012, 11:38 PM   #5
Lorraine's driver
ab_mach1's Avatar
and nice Mustang!
I moved your thread to our 96-04 tech section.
Instagram: @ab_mach1
Old 09-28-2012, 12:33 AM   #6
1shotkllz's Avatar
I had my throttle position sensor go out on me before, symptons I had were idle hang at 2k and only way to get it to stop was to shut the car off. If you're cruising with steady speed and feel a jerk or slight hesitation then you definitely have a miss fire.
Taken from experience.
1shotkllz is offline   Reply With Quote
rpms dropping for no reason Robbiemustang96 Pre-2005 V6 Mustang 8 09-24-2012 10:57 PM
RPM's are high?! Mustang_Madness 1996-2004 Mustang GT 30 02-08-2012 09:58 PM
Weird smell at high rpms? Mweigt07 2011-2014 Mustang GT 35 01-05-2012 02:38 PM
3:73 rpm's 02PONY 1996-2004 Mustang GT 1 12-12-2011 11:23 AM
RPMs Drop Randomly!? stangiusmaximus Pre-2005 V6 Mustang 6 10-04-2011 07:47 AM
» Members Mustangs
Ford
Fordguy
Ruby
RaginCajun
Add your Mustang
09:43 AM
