Teksid block - 32vNomad or someone help? - Mustang Evolution
Old 09-29-2012, 07:17 PM   #1
taylor98gt's Avatar
i just got back with my teksid motor, full motor oilpan to intake, except upper plenum and tb, even has ac compressor and pwr steering pump, if i get cams and get the heads on it redone will they be okay with supercharger/nitrous/turbo, depending on what i go with? or do i need to try to find the c heads? and what all do they come on? and where is a good place to find a 03/04 cobra rotating assy? sorry for all the questions, i just decided today ima go with the 4v, figured itd be a better starting point.
taylor98gt is offline   Reply With Quote
Old 09-30-2012, 08:50 AM   #2
Black99Snake's Avatar
mmr was having a sell on rotating assemblies over the summer may give them a call and see if they still having the sell i bought mine from them in may and spent 900 on it minus the crank. i think if u buy a crank from them in a kit its like around $800 give or take. the teskid block didnt come in the 03/04s so you already have a forged crank. but the pistons and rods are the weak point in this engine i have been told by a couple of relieable friends to just spend the money and get the forged internals instead of tryin to chance it on the stockers. o yea try dss racing they have a decent setup for a decent price ive heard good things about them. good luck man
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 09-30-2012, 06:05 PM   #3
taylor98gt's Avatar
yeah, ive got the teksid, got it tore down to short block today, post pics later, im prolly gonna go with a 5.1 stroker rotating assy, and then put stage 3-4 blower cams in her, and shoot her with a 200 shot till i can get a supercharger
Old 09-30-2012, 06:21 PM   #4
Lorraine's driver
ab_mach1's Avatar
<subscribed>
Instagram: @ab_mach1
Old 10-01-2012, 09:23 AM   #5
taylor98gt's Avatar
I got the motor and the guy said it had a dropped valve, and was ticking on the top end, I went home pulled the valve covers and one of the rocker arms came out from under the cam, so that's good cause I have no dropped valve! And then I ended the night with pulling one head off which was a pita lol. After work the other heads comin off and the oil pan.
Old 10-01-2012, 09:47 AM   #6
all the more reason to get a new valvetrain and built bottom end. lol atleast its not destroyed internally. did you check out mmr?
Old 10-01-2012, 10:29 AM   #7
Mzilla's Avatar
What do your teksid block come out of?
Mzilla is offline   Reply With Quote
Old 10-01-2012, 11:05 AM   #8
taylor98gt's Avatar
Mark 8
Old 10-01-2012, 11:11 AM   #9
Mzilla's Avatar
Originally Posted by taylor98gt
Mark 8
Ok I you plan on making any serious power you might as well order a forged Kellogg crank unless you can find a 96-98 cobra crank. The mark 8 cranks are cast not forged.
Old 10-01-2012, 11:36 AM   #10
also the 99s have the forged crank not sure about the 01s. that would also help to if you come across that as well not sayin Mzilla is wrong just throwin the info out there in case you come across one
Old 10-01-2012, 11:42 AM   #11
MMR has a 4.6-5.0 stroker crank on sale for $599
Old 10-01-2012, 02:12 PM   #12
taylor98gt's Avatar
Hell yeah, Ima jump on that then
Old 10-01-2012, 03:28 PM   #13
Mzilla's Avatar
I am just completing a teksid 2v build right now as we speak. My question is do you have a local reputable machine shop that can build a motor like this for a mustang wether it be a 2v or 4v. Here is a list of the items I purchased not including any machine work. I had a local engine builder that builds a lot of race engine do all the machine work and blue printing. Just food for thought.
Old 10-01-2012, 03:32 PM   #14
taylor98gt's Avatar
We have one that specializes in race engines I'm planning on getting the crank rods pistons etc and having them build it because they gaurntee their.work
Old 10-01-2012, 03:33 PM   #15
Mzilla's Avatar
That's awesome. Where are you located at?
Old 10-01-2012, 07:10 PM   #16
taylor98gt's Avatar
Bout 30 minutes from Lexington ky.
Well I pulled the other head off tonite, the valve dropped, bent, and broke, and went through the piston haha. The block is fine.
Old 10-01-2012, 07:56 PM   #17
Lorraine's driver
ab_mach1's Avatar
Glad you got started on your swap. I was wondering how soon. Are you going to keep your TR3650 or do you plan to upgrade down the road?
Old 10-02-2012, 04:37 AM   #18
taylor98gt's Avatar
mines a 98 i got a t45 or t5. cant remember which, but yeah ima keep it for now, the heads are no good, guess cobra heads are in order now.
Old 10-02-2012, 07:17 AM   #19
Lorraine's driver
ab_mach1's Avatar
Sorry man! I don't know why I thought you had a 2002. I know it's in you member name, just kept thinking you had an 02.
That's sucks, but at least you'll be getting an upgrade. Glad you got your project started.
Old 10-02-2012, 09:59 AM   #20
taylor98gt's Avatar
Yeah I'm Jus ready to get this crank and stuff in lol
Old 10-04-2012, 12:37 AM   #21
Nate98stang's Avatar
Just gonna jump in maybe u were thinking of me lol
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
turbo supercharger or bottle. alex_chab 1979-1995 Mustang GT 26 01-31-2012 08:59 AM
Bellhousing block mounts Cm644rodrigues 1979-1995 Mustang GT 2 10-20-2011 02:02 PM
Boss 302 long block ? BigRed1781 1979-1995 Mustang GT 17 10-09-2011 08:25 PM
10:39 PM
