Serpentine Belt - Mustang Evolution
Old 09-29-2012, 09:07 PM   #1
Mustang1804's Avatar
Send a message via AIM to Mustang1804 Send a message via Yahoo to Mustang1804
Serpentine Belt
I have a 1999 Ford Mustang GT (stock) and I looked at my serpentine belt and it is showing signs of wear and tear and I was actually considering changing it myself but I have been reluctant as I am a notice DIY'er. Could you guys run me by step by step directions as how to go about changing it. Thanks in advance.
Mustang1804 is offline   Reply With Quote
Old 09-29-2012, 11:58 PM   #2
t0t4lbl4ck0ut's Avatar
Just note how the belt is ran or there may be a sticker showing how. Then just use a socket and pry bar and pull on your tensioner and pull the old belt off and then run it all and pull the tensioner and put it on
t0t4lbl4ck0ut is offline   Reply With Quote
Old 09-30-2012, 12:12 AM   #3
Mathew r Wright's Avatar
There is like a filter that is attached to a pulley mount you'll have to pull it out of the way to get belt on or off also I just found out because I made this mistake but if you replace an alternator
There is a return wire kit you have to buy for any that are rates over the 105amp factory one... I had a 160 amp and replaced it too because I didn't know that. I guess factory return wire can't handle high voltage...
Mathew r Wright is offline   Reply With Quote
Old 09-30-2012, 12:18 AM   #4
? A filter on a pulley. I didn't have anything like that but mine is an 02 so it will be different
Old 09-30-2012, 09:02 AM   #5
Old 09-30-2012, 09:05 AM   #6
ID:	70596 Click image for larger version
This is what I meant sorry ...
Old 10-05-2012, 12:53 AM   #7
Ok thanks
2.3L Timing belt install deadsp0t 2.3 Mustang 13 12-05-2011 01:13 PM
belt size kid_kash_00 1979-1995 Mustang GT 6 11-15-2011 12:38 AM
Serpentine belt Snapple750 1996-2004 Mustang GT 1 11-11-2011 01:16 PM
belt length for no smog and AC eliminated Otlaw80 1979-1995 Mustang GT 8 08-30-2011 11:33 AM
10:36 PM
