hood removal - Mustang Evolution
Old 09-30-2012, 11:06 AM   #1
98GTCONV's Avatar
hood removal
I bought a cobra r hood and was wondering exactly what I need off of the old stock hood and how to remove it?
98GTCONV is offline   Reply With Quote
Old 09-30-2012, 11:38 AM   #2
Black99Snake's Avatar
question for you first. was the cobra r hood on a vehicle before or is it new? to remove your stock hood remove the 4 nuts that are on the hinges and the grounding strap thats bolted to the hinge area of the firewall and have someone help you lift it off. now for the other hood if its a new fiberglassed hood you will prolly need to have some body work done to make it fit and look right. when i did my hood i had to file down the sides and make them straight so it would fit between the fenders and not be closer or gapped at spots but mine was pretty much straight on top since its got scoops and not so much surface area. but if you got a used hood just have the friend help you lower it back on and put the nuts back on the new hood and adjust the hood so it shuts properly and fits between the fenders. if its to tight to the fenders just loosen the 4-6 bolts along the inside of the fender and pull out or in which ever is needed and tighten them back down pretty easy. but like i said if its a new hood just drop the car off at a local body shop let them test fit it and make it where it fits and let them do it. if its your d.d. then see if they can fit it one day and let you take the car if thats ok. and you prolly wont beable to use the heat shield on the new hood. hope that helps
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 09-30-2012, 11:53 AM   #3
98GTCONV's Avatar
Helps a lot thanks. It is used, so im going to go test fit now. The new hood does or does not need a heat shield?
Old 09-30-2012, 12:06 PM   #4
98GTCONV's Avatar
Just noticed the new hood doesn't have studs. Looks like it needs a bolt. Any idea what size?
Old 09-30-2012, 12:07 PM   #5
98GTCONV's Avatar
Here's a pic
Old 09-30-2012, 10:31 PM   #6
most likely a 8mm or 10mm fine thread. if you have some old bolts laying around i would find one that fits and go to lowes or someplace and buy 4 matching bolts. no you dont have to use your heatshield cause most aftermarket hoods dont have the holes for the push pins.
Old 09-30-2012, 11:09 PM   #7
98GTCONV's Avatar
One more question, does it need to be grounded? Thanks for your help!
Old 10-01-2012, 12:07 AM   #8
Venomouz831's Avatar
I didn't ground mines
)02 Gt, Founder of WE2G
Old 10-01-2012, 03:09 AM   #9
no you dont need to idky they put a grounding strap on a fiberglass hood that does not conduct electricity lol
Old 10-01-2012, 09:26 AM   #10
I have one on my stock Gt hood, dunno why but it came from the factory like that. I took it off cuz it looked stupid and was serving no purpose.
southernstang00 is offline   Reply With Quote
Old 10-01-2012, 09:51 AM   #11
they all do but i suppose its some part of a safety regulation
Old 10-01-2012, 10:48 AM   #12
Yeah I could see that, but that prolly added 50 bucks to the price lol
02:39 PM
