smokin - Mustang Evolution
Old 04-07-2008, 04:16 PM   #1
Angry smokin
hey guys, quick question: stang smokes some when i take off. whitish color. thinking valve stem seals. mechanic at work says might be pcv valve. how would that do it? any thought? thanks guys...
white 98 gt is offline   Reply With Quote
Old 04-07-2008, 09:26 PM   #2
MonteCitan's Avatar
Re: smokin
Whitish? Have you replaced your intake gaskets before? If not you may need to
Is your coolant level dropping at all?
It could also be condensation if its cooler than usual outdoors, 60 or below is all your car needs to steam a bit
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-08-2008, 02:02 PM   #3
Re: smokin
thanks for responding... yes, white-ish. not all white, not black. put replacement intake going on 2 years ago. doesn't smell like colant, smells oily. thanks for your input.
Old 04-08-2008, 05:34 PM   #4
Re: smokin
Could be a piston ring going bad. Might want to do a compression check. Can't hurt.
12:16 PM
