Rear end problem - Mustang Evolution
Old 10-03-2012, 09:04 PM   #1
waybad's Avatar
At the strip today while I was in the burnout box friend noticed that my drivers side tire remained still during my burnout. Could it be because of worn clutches? A guy there said just replacing the fluid in my rear end with some kind of synthetic fluid, or some kind of non slip fluid would stop the problem. Any ideas as to what it could be or how to fix it? It's a 2000gt
waybad is offline   Reply With Quote
Old 10-04-2012, 10:09 PM   #2
wolfstang03's Avatar
Same thing happened to me at the track. Dude said it was the clutches...I figured id rebuild the whole thing. 3.73 ford racing gears, trac lok rebuild kit, installation kit, royal purple gear oil, and had to break off and replace my 2 rear wheel sensors, plus the.price of installation ... $1150
--WOLFSTANG 03--
wolfstang03 is offline   Reply With Quote
Old 10-05-2012, 09:22 AM   #3
Lorraine's driver
ab_mach1's Avatar
If you gears and axles are in good shape, you can probably just get a rebuild kit for the clutches, etc. Might be considerably cheaper.
Instagram: @ab_mach1
Old 10-05-2012, 01:03 PM   #4
waybad's Avatar
Thanks guys! I think it may be the clutches. I looked at my gears and axles. They seem to be in good shape. I think I'm just going to replace the clutches and see if it changes anything. Thanks for your input guys!!!
Old 10-05-2012, 01:10 PM   #5
Lorraine's driver
ab_mach1's Avatar
Here's the rebuild kit...
Ford Racing 8.8" Traction-LOK Rebuild Kit w/ Carbon Discs M-4700-C - Free Shipping!
For your axels, you'll need to get the 28 spline S springs to go with thyis kit. When you refill your rear diff, make sure you use the Ford friction modifier. I could find the S springs on AM's website. Those, you might be able to find at a local auto parts store.
http://www.americanmuscle.com/frpp-f...-modifier.html
Old 10-05-2012, 07:05 PM   #6
The royal purple has the.modifier right in it
--WOLFSTANG 03--
Old 10-05-2012, 08:00 PM   #7
Lorraine's driver
ab_mach1's Avatar
I went ahead and put it in mine with Royal Purple, but I think I've heard people say it has it in there already.
Old 10-06-2012, 12:23 AM   #8
t0t4lbl4ck0ut's Avatar
If your going to rebuild it why not just replace it. Its already failing so its a perfect time to build it better while your in there. And besides the price of the axles it wouldn't be much more.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 10-06-2012, 06:28 AM   #9
waybad's Avatar
I would like to, I just don't have the extra cash right now. I have just found out I have a baby on the way. And I'm 19 so with school, work, and saving up money I'm trying to save everything I can. I should honestly sell the car, but I just can't bring myself to do it. So I'm just doing what I can here and there.
Old 10-06-2012, 06:39 AM   #10
Way to be responsible. You will always be able to buy another
Old 10-06-2012, 07:28 AM   #11
Lorraine's driver
ab_mach1's Avatar
+1
Old 10-07-2012, 05:06 PM   #12
32vNomad's Avatar
Just rebuid it. Why replace something that easy to fix. Also ford offers kits with the spring and modifier.
32vNomad is offline   Reply With Quote
Old 10-11-2012, 05:56 PM   #13
Sonicblue11's Avatar
How much are they? I need mine rebuilt
Sonicblue11 is offline   Reply With Quote
Old 10-11-2012, 09:12 PM   #14
32vNomad's Avatar
American Muscle sells Trac-Loc rebuild with carbon discs. For 99.99 on sale.
Ford Racing Traction - LOK Rebuild Kit w/ Carbon Discs - 8.8in (86-12 V8; 11-13 V6)
12:16 PM
