Needing some help. trans noise? - Mustang Evolution
Old 10-04-2012, 08:04 AM   #1
Tylercribbs's Avatar
Region: Arkansas
I have a weird noise from 4th and 5th gear that is a grinding kind of sound. It doesn't do it when I am going slower. I only have problems with this noise when I am going around 55-60+. Any ideas on what this could be?
Tylercribbs is offline   Reply With Quote
Old 10-04-2012, 12:00 PM   #2
Jcurto1's Avatar
Could be syncros in the tranny. If you push the clutch and don't shift right away does it still do it?
Jcurto1 is offline   Reply With Quote
Old 10-04-2012, 01:14 PM   #3
Region: Arkansas
It doesnt do it when i shift. It is in the gears i guess. Shifting it is fine, it is while it is in the gear when it grinds continuously.
Old 10-05-2012, 09:09 PM   #4
how longs it been since u had a clutch job...possible that ur throw out bearing went out,if not check ur fluid make sure theres no metal shaving in it...
RepumSN95 is offline   Reply With Quote
Old 10-05-2012, 09:58 PM   #5
Lorraine's driver
ab_mach1's Avatar
Is this grinding noise when your in gear moving, or when your putting it in gear?
Instagram: @ab_mach1
Old 10-06-2012, 09:39 AM   #6
Region: Arkansas
The noise is while im in gear moving. :/
Old 10-06-2012, 10:08 AM   #7
03whitey's Avatar
Sounds like someone didnt do a good job setting your gears up to me
03whitey is offline   Reply With Quote
Old 10-06-2012, 10:49 AM   #8
Lorraine's driver
ab_mach1's Avatar
So it's only in 4th or 5th and going ~55-60mph, that you hear the noise. You can't repeat the noise in 3rd at the same speed?
Old 10-06-2012, 03:16 PM   #9
Region: Arkansas
My car is to loud to hear it in 3rd so it might and its 55+. The faster i go, the worse it gets
10:27 PM
