Remove CD player now low-volume - Mustang Evolution
Old 10-04-2012, 07:23 PM   #1
WheelStander's Avatar
So I removed my CD player now my volume is super super low and I can barely hear it on my radio any ideas?
99 gt Mach 460 system.
Thanks for any comments.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 10-04-2012, 07:58 PM   #2
Venomouz831's Avatar
I'm guessing you took out an aftermarket unit? Therefore it doesn't create as many watts and volume would be lower
)02 Gt, Founder of WE2G
Old 10-04-2012, 08:15 PM   #3
I took out the original cd player for gauges.
Old 10-04-2012, 08:18 PM   #4
So what are you using now then?
Old 10-04-2012, 08:24 PM   #5
Nothing I just took the cd player out and unplugged the wires.
Old 10-04-2012, 08:47 PM   #6
Hmm not sure then. Hopefully someone will chime in
Old 10-04-2012, 08:48 PM   #7
sally2002's Avatar
I don't no if this will work but can you plug it back in and see if it's back to normal. Maybe the two are connected somehow. That's just a guess
sally2002 is offline   Reply With Quote
Old 10-04-2012, 09:14 PM   #8
The cd player works with the head unit to send power to the amps. You probably only have highs as well
Old 10-05-2012, 02:17 AM   #9
Ok yeah only highs.
Is there a work around?
Old 10-05-2012, 04:19 AM   #10
Butch's Avatar
Region: New Mexico
I too would like to know if there is a way around, I wanna panel gauge the beast
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 10-05-2012, 08:23 AM   #11
You're going to have to find a way to send power to the amps.
Old 10-05-2012, 10:46 AM   #12
Ah thanks. I'm taking it apart I see the amp back there.
Thanks!
Old 10-05-2012, 11:12 AM   #13
Thanks!
There are three amps. Easiest way is an aftermarket headunit with a mach 460 harness
Old 10-05-2012, 04:03 PM   #14
It's never easy, maybe I'll just run it up to best buy and spend 150?
Old 10-05-2012, 05:55 PM   #15
I can buy any stereo and then buy harness?
Where do I get harness?
Old 10-05-2012, 05:59 PM   #16
Any good stereo shop or online. Just make sure its for the 99-01 mach 460. Not 100% sure if 02-04 harness is the same.
Either way it will have two pigtail connectors instead of one like the normal stereo
Old 10-05-2012, 07:28 PM   #17
Ok thanks.
Thinking about this one:
http://m.bestbuy.com/m/e/product/det...=1218524493327
Thoughts anyone?
---------- Post added at 08:28 PM ---------- Previous post was at 08:27 PM ----------
Best buy has the harness for 40 bucks.
Old 10-05-2012, 08:49 PM   #18
frank07stanggt's Avatar
Ok thanks.
Thoughts anyone?
What is the part number for the harness?
frank07stanggt is offline   Reply With Quote
Old 10-05-2012, 09:04 PM   #19
I'll find out tomorrow...what should I look for?
---------- Post added at 10:03 PM ---------- Previous post was at 10:02 PM ----------
Going early when they open.
---------- Post added at 10:04 PM ---------- Previous post was at 10:03 PM ----------
It's a "kit" whatever that means.
Old 10-05-2012, 09:35 PM   #20
M97cobra's Avatar
Wen got my car amps were blown and crackin sound I bypassed the amps put in my pioneer works great
M97cobra is offline   Reply With Quote
Old 10-06-2012, 08:54 AM   #21
What do I need to ask for cause I'd like to get an aftermarket radio and still use the factory amps.
Old 10-07-2012, 12:28 AM   #22
M97cobra's Avatar
Have them test your amps make sure they work properly and pic the deck u want you'll prob need new harness and that's probley it
Old 10-07-2012, 12:55 AM   #23
Mine sound good. I just want an auxiliary or Bluetooth connection for my phone. CDs are "old school". Lol
Old 10-07-2012, 01:20 AM   #24
M97cobra's Avatar
Two weeks ago went into local audio shop and for me I like pioneer and there latest model has Bluetooth and can run your calls thru your sound system full audio band multi color changeable display and remote for around 200 installed that's wut ill be getting this winter sometime
Old 10-08-2012, 10:56 AM   #25
Did you get everything hooked up? How does it sound going through the factory amps? Still have bass?
Old 10-08-2012, 12:16 PM   #26
Not sure Best Buy geeks did some tests and couldn't guarantee it would work after they installed the new head unit.
So Im not sure what I am doing with the stereo at this point.
Turned my focus to engineering and making my heat exchanger bracket.
Putting it off for a couple weeks until I can do some tests myself.
I'll update as soon as I figure it out.
Thanks for the help everyone.
Old 11-17-2012, 01:43 PM   #27
RChadstang's Avatar
I'm having a similar issue, I put my Pioneer AVH-4400BH in my 04 GT. At first I only had hi's from the tweeters. Turns out I put the RCA cables in the AV in instead of the RCA amp out. All I had to do was plug them in the right slot and connect my remote wire. (I used the aftermarket harness) Now I have power to my rear speakers, but the speakers in my door are very quiet, which makes the sound in my car very un even. Lots of bass in the back, hi's up front but the midrange is muddy and sloppy no matter what I dial in my EQ.
RChadstang is offline   Reply With Quote
Old 11-17-2012, 04:18 PM   #28
Guy at best buy said there was and extra amp that needs to be jumped.
I went hi tech with this bad *** head unit.
Crap it even downloads my phone book from my iPhone.
The Bluetooth integration is better than my buddies Beamer lol.
The hd radio is amazing.
09:11 AM
