Car wont turn over - Mustang Evolution
Old 10-06-2012, 10:40 AM   #1
Car wont turn over
I'm having some problems with my 2000 gt I recently replaced my motor with another stock motor but when I go to turn on the car it doesn't turn on it doesn't even turn over when i open the key all the electrical work and everything is fine but once I turn it enough to start it everything shuts off
Luis24 is offline   Reply With Quote
Old 10-06-2012, 11:02 AM   #2
Lorraine's driver
ab_mach1's Avatar
Did you do the engine replacement or a shop?
Instagram: @ab_mach1
Old 10-06-2012, 11:45 AM   #3
deadsp0t's Avatar
Sounds like a short/bad ground. Maybe something in the starting circuit is loose or in hooked.
That's unimpressive
Old 10-06-2012, 05:25 PM   #4
I did the swap and what ground cables should I be checking for? We're are they? I checked a few but all seem to be bolted on nice and tight I'm all out of options but the car does turn on because Incan turn it on with a screw driver by touching the bolts on the starter so the car is fine. Thank for all your help
---------- Post added at 05:25 PM ---------- Previous post was at 05:24 PM ----------
We're is the starting circuit? Or what is it I'm kind off new to this thank you
Old 10-06-2012, 05:29 PM   #5
deadsp0t's Avatar
Hmm with that bit of info you might have a wiring harness issue although I'm no expert at 4.6's or wiring. Sounds like the key is not talking to the starter, maybe an anti theft issue(pats)..
Wish I could be more help.
That's unimpressive
Old 10-06-2012, 05:59 PM   #6
Thank you ill see what I can dig up or I'll get another key
Old 10-06-2012, 06:20 PM   #7
deadsp0t's Avatar
If its the pats I don't think a new key will fix it. I think it's a programming thing for the ecu.. I'm sure someone else will chime in..
That's unimpressive
Old 10-06-2012, 06:29 PM   #8
If its the PATS system,,the antitheft light will flash rapidly when you turn the key to start
mymustang is offline   Reply With Quote
Old 10-06-2012, 08:20 PM   #9
It doesn't flash rapidly it flashes slowly like every two sec
Old 10-06-2012, 09:41 PM   #10
1996mustang's Avatar
Last time i had that issue i replaced the reistor circuit that was by the lock cylinder its like a ring that gows aeound it.....pardon the mispells runnin on 2 hr sleep and phone hates me -_-
Old 10-06-2012, 09:49 PM   #11
We're is that part located at? And was it expensive
Old 10-06-2012, 09:54 PM   #12
Its located around the lock cylinder in the steering wheel its a black circle qith a harness its for the pats. Last time i think was 79 bucks at my ford dealership not too sure about it now ill post up a pick of it in a sec
---------- Post added at 11:54 PM ---------- Previous post was at 11:52 PM ----------
http://www.google.com/search?tbm=isc...&bih=559#i=118
Old 10-06-2012, 09:59 PM   #13
That would be helpful thanks does autozone not Carry it?
Old 10-06-2012, 10:04 PM   #14
I assume only the dealer to be honest. Autozone wouldnt carry pats stuff so dealer sadly is the only option
---------- Post added at 12:04 AM ---------- Previous post was at 12:03 AM ----------
Btw link to pic is on previous post if u didnt see it yet
Old 10-06-2012, 10:07 PM   #15
Lorraine's driver
ab_mach1's Avatar
i believe you still need to take it to a dealership to have everything married together so PATS will work with the new parts. Somebody correct me if I'm wrong.
Old 10-06-2012, 10:14 PM   #16
Would a used one from eBay work?
Old 10-06-2012, 10:19 PM   #17
I didnt have to to be honest i replaced the part and turned key and haleluya or however its spelled lol it started up gine havent had any issues for over a year and a half and counting
---------- Post added at 12:16 AM ---------- Previous post was at 12:15 AM ----------
Not too sure on the used one to be frankly honest
---------- Post added at 12:19 AM ---------- Previous post was at 12:16 AM ----------
Used scares me on that piece due to the fact its a vary fragile circuut any crack causes a break in the necessary resistance circle and u would be back to step one. On this issue i would do dealer. However have u looked into 2 slow flashes of the pats? Its a code saying whats wrong in the pats system if i find it ill post link up
Old 10-06-2012, 10:20 PM   #18
Lorraine's driver
ab_mach1's Avatar
Maybe, I don't really know. It's worth looking into. It might save you a few bucks in the cost of the part. I'm sure you know dealer parts are $$$.
Do you happen to have a remote start kit or an aftermarket alarm system?
Old 10-06-2012, 10:27 PM   #19
Good question azure....would be nice to know if it does....plus how many flashes does it give per second would help to finding the cure
Old 10-07-2012, 01:11 AM   #20
No I don't have anything aftermarket on the car as far as alarm systems go
Old 10-07-2012, 04:47 AM   #21
Yep they call that the antenna ,or transponder,,but usually the light will blink rapidly when you try and start,,
Old 10-07-2012, 04:55 AM   #22
Its probably a dealer item,,usually the light flashes rapidly when you have a problem with that system,I would check the fuses and relays first,,check the PATS fuse,,and pcm fuse,,it may have a couple of pcm fuses..If you have a meter or test light you can test them without removing them,,the fuses that is..Use your owners manual
Old 10-07-2012, 09:36 AM   #23
Are all those fuses under the dash or are they in the engine bay?
---------- Post added at 09:36 AM ---------- Previous post was at 09:35 AM ----------
And my light doesn't flash rapidly it flashes slowly
12:33 PM
