Spring issues - Mustang Evolution
Old 10-06-2012, 02:59 PM   #1
Matticus's Avatar
Spring issues
So me and some friends of mine were putting on my springs today and have run into a problem. The back two went on no problem, but the crappy spring compressor we rented from the auto parts store is too short to get the front springs off. Anyone know what I can do? I'm kind of in a bind here :/
Matticus is offline   Reply With Quote
Old 10-06-2012, 03:01 PM   #2
Mzilla's Avatar
Upload a pic of what your working with And I can help
Mzilla is offline   Reply With Quote
Old 10-06-2012, 03:13 PM   #3
Matticus's Avatar
We got the compressors set as high and as low as we can get them, and they're meeting in the middle now, still can't get the spring out.
Old 10-06-2012, 05:12 PM   #4
Mzilla's Avatar
That will work have your buddy push down with his foot n the control arm and yank it out. Make sure you have the sway bar unhooked and the brake caliper is detached
Old 10-06-2012, 06:33 PM   #5
Matticus's Avatar
It's still not compressed enough, pic may not accurately show. Called a friend who runs a parts store and he said we need to drop the a arm and take the ball joints out. I went and rented the pickle forks but that'll have to be a job for tomorrow
Old 10-06-2012, 11:54 PM   #6
1slosix's Avatar
i don't use a spring compressor....just unbolt the shock from the a-arm (2 bolts)...let the a-arm drop...and pull the spring out by hand (use a flat head screwdriver if it's stuck)..then reverse for reinstall...super easy to do
carving corners like a boss
Old 10-07-2012, 07:52 AM   #7
Mzilla's Avatar
I also have never used a spring compressor. Remove the 2 lower strut to knuckle bolts
Remove the brake caliper
Remove the sway bar bolt
Push down with your foot on the lower control arm and pull the spring out.
This is how I have done this for years
Old 10-07-2012, 09:00 AM   #8
Sonicblue11's Avatar
+111 super easy to do us right! No need for spring compressor just drop that a arm and your in there!
Sonicblue11 is offline   Reply With Quote
Old 10-07-2012, 09:52 AM   #9
DaBluedude's Avatar
Yeah. But instead of a screw driver use a big ****ing prybar. The isolator often sticks into the a arm. You definitely need to in bolt the shock.
2003 Mach 1
Old 10-07-2012, 10:50 AM   #10
poncho2049's Avatar
I didn't use a compressor on mine. Two pry bars and my foot lol
poncho2049 is offline   Reply With Quote
Old 10-07-2012, 07:17 PM   #11
Matticus's Avatar
Got it all finished today with new shocks and struts as well. Will post pics tomorrow if I remember lol
---------- Post added at 08:17 PM ---------- Previous post was at 08:17 PM ----------
Thanks for the help by the way, we ended up doing what you all said about lowering the a arm and it was much easier
07:52 AM
