2v tf or 4v? - Mustang Evolution
Old 10-07-2012, 10:57 PM   #1
Snapple750's Avatar
2v tf or 4v?
If I swapped in a 5.4, should I go with a 2 valve trick flow, or a 4v?
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 10-08-2012, 04:24 AM   #2
1996mustang's Avatar
4v is what i suggest however.not sure how that would clear cause of 4v heads
Old 10-08-2012, 08:14 AM   #3
CodyNelson's Avatar
Region: West Virgina
5.4 DOHC won't fit under the stock hood
Old 10-08-2012, 08:30 AM   #4
Snapple750's Avatar
I figured as much, although I think I read somewhere that it will fit tightly.
2 Legit 2 Quit
Old 10-08-2012, 08:31 AM   #5
CodyNelson's Avatar
It won't fit
Old 10-08-2012, 11:21 AM   #6
It would...........but the amount of modifying and cuttin firewall and frame is not worth tje headache.......specially cutting intp the frame
Old 10-08-2012, 05:02 PM   #7
CodyNelson's Avatar
If it requires cutting the frame I consider that not fitting.
01:00 AM
